G2000S
Bee-Positive
Nov 16, 2022
1,148
1,063
Amsterdam, NY
Have you tried Messick's - they have a parts locator. Not saying they can find one but it's worth a try.
pigdoc
G1800S L2500
Aug 19, 2022
403
350
SE Pennsylvania
Try taking the relay to a good auto parts store, if you can find one. Could be that there is a generic replacement. Or not.
-Paul
pigdoc
G1800S L2500
Aug 19, 2022
403
350
SE Pennsylvania
Why do you think you need a new one?
Oh, good call, Dan.
On my G1800, the starting circuit is very particular about the safety switch on the brake pedal. I have not gotten under there yet to see if there is any opportunity to adjust it. Point is that it is sensitive, and if doesn't function correctly, it will mimic a bad relay.
Also, I find that the starter circuit is sensitive to battery amperage. In other words, if the battery is not fully charged, I just get a click when I twist the key. Twenty minutes on the battery charger and the tractor cranks right up. [My battery is getting old.]
-Paul
7,322
Oh, good call, Dan.
-Paul
Thats pretty much the story of most lawn tractors made today and the foruns are full of stories just like yours.
The relay is probably not going to actually fix the problem. I gave up trying to fix my G2160 and just jumper the starter. Cranks every time.
tbk5
L3710, L3010, ZD1211, RTV900xt, GR2100, lots of 3pt equipment
Sep 24, 2013
184
94
Central AL
When the relay went on the starter for my GR2100, I took the Denso part number off the starter and matched up a compatible solenoid on Amazon. It was a $20 fix.
