Thinking about under fence weed control
Shawnba67
21
9
S.E. IN
Curious if anyone has thoughts. I have 20ac in field fence about a third of it has a severe honeysuckle infestation. I VERY MUCH DONT WANT TO SPRAY POISON.
I had a M59 (60hp 4wd 9k lbs) with ssqa and front hydro. Ive had an idea or two on mechanical ways to weed. Is there a toothed rig i could bolt onto my bucket or a ssqa blank plate that maybe could be shoved under the fence to cut the stems a few inches underground. In my head if this helps explain Imagine running pallet forks into the dirt only 7ft wide and wouldn't need to be more than a foot past the fence and couple inches deep.
Or make suggestions on easier ways!
Unless its spray them, no need to type that out.
OntheRidge
Nov 1, 2020
437
511
Goats?
imnukensc
BX2380
Sep 10, 2015
761
705
Midlands of SC
30% vinegar, salt, and some Dawn make an excellent weed killer. Yeah, ya gotta spray it and I don't know how well it would work on honeysuckle, but it's not poison.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
473
108
NZ
The distance between posts and how high off the ground the bottom wire (or rail or whatever) is could have a bearing on the solution. Can you describe those and provide a photo of that and mature honeysuckle stems (several varieties I understand). I prefer to avoid spraying too, and found that simply depriving the weed of the opportunity to regrow and sprout leaves has killed it. Takes a couple of years of persistence, but in my mind worth it. Your idea about the pallet forks may do that. Also mowing with something that can cut the stems low down under the bottom rail/wire, and avoiding the posts :cool:
Shawn T. W
Dec 9, 2024
429
772
SW Missouri Ozarks
I had honeysuckle and multi-flora roses take over my five wire fences prior to me buying my place, best I came up with was the next to biggest trimmer Stihl makes with a metal blade, gloves and a lot of sweat! Did about a mile of this!
Had to chainsaw out some of the cedars ...
With a woven wire field fence, it would be worse! Even if you "cut it off" at the ground, it's still gonna be all through the fence, especially the honeysuckle twists around and through it, depending on your budget, might be better to bulldoze it all into a few piles, once dead, burn it all, take wire and posts to metal recycling yard, build new fence!
3,492
2,074
By field fence, I assume you mean mesh of some sort. I've seen weedeater-type trimmers that attach to your mower that can trim under a fence and deflect around the posts, but I don't think it would work very well around your kind of fence.
I understand your aversion to chemicals. You could minimize the usage by cutting the stems and applying 2-4d or similar to the cut stems. You could probably come up with a tool to do what you've described, but that honeysuckle would be back up in no time. Could you grab the stems and pull it up by the roots?
2,445
Look at stump buckets or tooth bars like Piranha or EA Wicked
they may be able to help do the job.
imnukensc
BX2380
Sep 10, 2015
761
705
Midlands of SC
So you can drink it? Because it's natural doesn't mean it not poison... apples have arsenic... just saying...
It's not "poison" in the sense I took the OP's statement. That is, it's not glyphosate, 2-4d, triclopyr, etc., etc., etc. Gimme a break. You know what I meant and what the OP meant. I'm going to have an apple.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
837
747
E.
old time farmer here.
how about a propane weed burner?
the vinegar mix thingy is an interesting one. Its very common talk in our coffee shop with a lot of garden women claim its fantastic at killing the weeds. Vinager et all will / may kill what it contact with by speeding up dehydration/dry down by stripping off protective covering but will not kill what it doesn't touch (like roots) (its a contact thing) but some salts have beneficial benefits to plants (think fertilizer value), and some soaps contain potassium which again is a fertilizer.
So the women wonder why the plant looks dead but comes back to life with a vengeance.
I would vote an ag. propane weed burner if the generally accepted tried and true methods are not acceptable
Shawn T. W
Dec 9, 2024
429
772
SW Missouri Ozarks
Just cutting it off at the ground will still leave all that mess woven up in the fence, and the roots are still in the ground, ready to spring back up ... Fire will burn off the galvanized coating of the fence and it will rust even faster ...
My plan for around my vegetable garden I'm working on putting in, is to put down a double layer of weed barrier, then mulch, then put the fence on top of that ... The other mile of fence gets sprayed with weed killer or old oil drizzled on it ...
5,850
really 'old school', used in vineyards, is to direct steam to the bottom of the fencing. Guys mount a 'steam genny' onto tractor,point steam nozzle to the ground, then run the fence line. kills the weeds.
since it's only water...NO 'poison' chemicals are used !
GrumpyFarmer
4,430
Are you wanting to trim and maintain, remove, or eliminate weeds from the ground to bottom of fence?
As I read not wanting to poison (I am assuming that means no chemicals), but to me that means most likely require regular maintenance. Is that correct?
if wanting to maintain I’d suggest a flail paired with a side trim disc mower, but not understanding current fence and your goal I’m not sure you want to maintain. If it’s full of honey suckle I am not sure the side trimmer would work, much less is the fence have a space to the ground to allow it.
Shawnba67
21
9
S.E. IN
Several to respond too.
The suggestions of the vinegar mix and the weed burner. Ive thought of both alot Im pretty certain both will cause extra corrosion of the fence. Not 100% what temps hurt galvanization but any fence comes out of campfire is suddenly rusty.
The fence is on the ground posts at 20ft. I may need to just raise the fence up. It's 5 yrs old and it turns out the rif raf wildlife i was concerned with easily going under easily go through! Lucky that cows are big
5,850
steam shouldn't hurt the fence...kinda same as rain water... tossing galv steel in fire is a bad thing ! shouldn't do that or weld, as fumes are toxic. tossed in fire, fire burns off the zinc(galv) leaves bare steel which will rust.
