Kubota L47 TLB 50 Hr Service
NRoweyL47
2025 L47TL
Apr 9, 2025
RI
Doing the Hydraulic / Transmisson and Hydrostatic Filter change on 2024 L47 TLB.
The maint book says to change these filters at first 50 HR Service .
Looks like they all use the same fluid with a single fill UDT fill port behind the Seat.
My question is one filter is on the Left Lower Center facing horizontal and two others on the right lower center facing Vertical.
The service tech at the dealer told me to use a vacuum cleaner to reduce the fluid loss.
Does anyone know what he means?
JasonW
481
270
Al
Hold the vacuum on the fill port to create a vacuum as you remove and install the new filters. A separate person operating the vacuum makes it easier.
kcs 61
B2650 , BH77,FDR1660, PFL2042,RCR1860,RB1672, RTR1258,BB1260
Apr 8, 2024
40
21
Va
I used my shop vacuum when I changed mind on my 2650 Wife held the hose on the fill port while I changed the filter. And YES it does work. But not enough suction to pull the SUDT up in the vacuum
5,172
Yup.....you are then simply trying to pull a partial vacuum on the fluid tank.
Vlach7
L47 305DT JD500C
Dec 16, 2021
371
265
Frazier Park Ca
Wish I would’ve known that when I did mine forgot to move the magnet to the new filter. Had to pull them off and lost 5 gallons of hydraulic fluid.
NRoweyL47
2025 L47TL
Apr 9, 2025
RI
So If I stick my wife at the fill port with my Dewalt shop vac while I pull the three filters I should be good to go? Wow cool trick...
NRoweyL47
2025 L47TL
Apr 9, 2025
RI
Are Magnets part of the new filter or is this somthing that needs to be removed and cleaned?
JasonW
481
270
Al
Yes, they will need to be removed , examined, cleaned and put back on,could take a minute or two.
Which filter? Looking at the parts diagram the hydraulic filter HHTA0-37710 includes the magnet. But can also be bought separately. (For $17 if you happen to break it.)
The HST filter HHTA0-59900 doesn’t show a magnet at all.
retired farmer
tractor, loader, cutter, blade
May 25, 2020
188
107
sheridan
Guess I am blind in my dotage but don't remember any magnets on any filters. I have a L3301 HST and owned it since new and changed and serviced all filters and fluids at specified hours since new. Are these magnets in the filters or where if not?
rr
