I have a G4200 with the RC44 gearbox, which is the same as the RC40 deck. Unfortunately, the gearbox was low/ran out of lube (that is on me) and it seized the bearing at the top with some shrapnel. Plan is to remove the bad bearing, clean it well and ensure all metal pieces are removed and then install a new bearing.
I have seen this, and while helpful, does not go into details on how to disassemble the gearbox. I was able to get the gearbox off the deck and on the bench.
www.orangetractortalks.com
Here is the diagram for it from Messicks. https://www.messicks.com/catalogs/k...4-quot-mid-rotary-mower/mower/i00200-gear-box
On the right side, I am working on bearing #170
Also, I tried to remove the pulley but I am not sure how to remove this. It looks like there is a stake where the pulley and shaft meet, but it’s recessed in there and I don’t see how to remove it.
Pic shows the bearing and what is left of the balls. I was able to remove the outer race and balls with some cutting and brute force, but the inner race is on the shaft really good. How can I remove this? It is not high enough to get a bearing puller on. I tried heat and penetrating lube to no avail.
Or does anyone have a WSM/disassembly manual for the deck?
RC44-G mower deck gearbox
Not good. Anyone know how to rebuild a mower deck gear box? Previous owner removed the external clip from the shaft, I see no shims, no o ring and they packed it with grease. The good thing is it still works, the bad thing is it makes too much noise.
