Teach me about hydraulic motors
PHPaul
Apr 2, 2015
1,187
1,369
Downeast Maine
www.eastovershoe.com
Grandson has been pricing specialty mowers for mowing orchards and ditches and such. Lots of suitable technology out there, but the prices will take your breath away.
I'm thinking of building a hydraulic version of my diesel string trimmer. The idea is that the string head would be hinged so it could tilt up/down. It would involve a PTO mounted pump to run a hydraulic motor on the string head. What I need to know is whether or not my combination of components is suitable. I'm looking for 3-5 HP at the string head. RPM can be achieved by suitable pully ratios if needed.
Here are my first thoughts:
PTO Pump - Surplus Center 9-8902-3, 7.4 GPM @ 540 RPM
Motor - Surplus Center 9-16442-12, 5.2 GPM @ 1500 PSI
Tank - Surplus Center 9-8416-5, 5 gallon capacity
Insights/Suggestions appreciated.
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
261
210
Indiana
With 7.4 gpm from that pump, you could exceed the max flow of that motor. With hydraulics, you don't just add a simple 'valve' to reduce the flow rate. I'd start with a motor/pump combo that might work with no control other than 'on/off'.
According to TractorData, you have 5 gpm available from your B2650. Have you ruled using that out for some reason?
That aside, what RPM do you need? I'd suggest knowing that up front, as the selection of a motor can be optimized that way. Little gas weed whips are in the 5000-1000 RPM range. With a larger head, are you thinking something about half that?
PHPaul
Apr 2, 2015
1,187
1,369
Downeast Maine
My mechanical design works well at about 3000-3600 RPM. I based that on the walk behind 4-stroke trimmer that uses direct drive from motor to string head.
If this materializes, it'd be for my grandson's 3046R John Deere. Not sure where I'd tap into the system to use the tractor's hydraulics.
I'm assuming flow rate on the PTO pump is directly related to RPM. Yes or No?
InTheWoods
Nov 17, 2023
261
210
Indiana
It has the flow. Are other hydraulics being used at the same time as the trimmer?
Yes.
And similarly, the motor speed is directly related to the flow rate.
InTheWoods
Nov 17, 2023
261
210
Indiana
Assuming there's another remote, seems like it'd be worth considering.
5,655
For fixed didplacement pumps like that PTO pump flow is proportional to RPM. I would suggest you add a control valve with a motor spool to your design. Only add $100 to the cost.
InTheWoods
Nov 17, 2023
261
210
Indiana
That would require tying the valve lever in the open position and restrict flow wouldn't it?
I'd be inclined to select a motor with enough displacement that it hits the desired RPMs with the full flow your pump can provide. You'd end up with a motor having more displacement (and thus torque) than needed, but a pressure relief valve would effectively limit the torque, if needed.
That said, I've pondered similar projects, but never done it - so I'm not claiming to be an expert here...
5,655
  1. Flow determines motor speed
  2. Pressure determines motor torque.
  3. In his application pressure will never go higher than needed to spin the trimmer head.
InTheWoods
Nov 17, 2023
261
210
Indiana
I know - just suggesting a pressure relief valve as a safety measure. I'd expect the pressure to be quite low normally, unless something gets jammed...
InTheWoods
Nov 17, 2023
261
210
Indiana
So what do you think about using the tractor's hydraulics for this instead of a dedicated PTO-driven pump?
PHPaul
Apr 2, 2015
1,187
1,369
Downeast Maine
It's certainly an option.
He already has a 3rd function for a grapple on the bucket and I'm not sure what plumbing would be required (or if ports are available) to tap into power-beyond.
Worth investigating if he/we decide to build it. Save about $700 what with the pump, tank, filters and fittings.
3,449
2,025
Should be doable, but there are considerations,
Many hydraulic motors have back pressure limits unless a case drain is provided,
Your other hydraulic functions might rob the motor when they're used simultaneously.
Have you considered mechanical drives? I'm not sure what flexibility you're after. But if it's just rotate the plane of the trimmer, could you pivot it on a jack shaft? Use belts similar to your picture, but run the shaft horizontally. Swing the trimmer support frame on the jack shaft, twist the outboard belts to get from vertical to horizontal. Then you'd need to drive from the PTO to the jack shaft. Maybe a shaft with u-joints from the PTO to a shaft on pillow blocks mounted parallel to the other shaft. V- belts interconnecting, with tensioner. With double speed increase by appropriate pulley sizes?
5,655
Assuming you have sufficient flow that would be my choice.
Heat is the main enemy. A dedicated valve with motor spool and direct tank return is optimal. The problem with a direct tank return is it will disable all down stream functions.
5,791
adding to potree's post...
use a 'mower deck right angled gear box 'whatever they're called. to connect to PTO shaft and another for the 'wippersnipper head'.
Very SIMPLE, reliable, EASY . bodge in a 6:1 reducer 'backwards' and you get the 3000+- RPM you're looking for.
PTO shaft-->1:6 increaser->right angle gear box->drive shaft-->RA gear box--'head'
5,655
Vbelts.
