Telescopic stabilizer kit opinions?
Mustard Tiger
BX23S
Jun 26, 2025
95
223
Pacific Northwest
I have a BX23S, and the backhoe was something I really wanted and will use quite a bit. I do have other attachments (land rake and waiting for a box blade to arrive). I will be using the backhoe and box blade most of the time, so a quick hitch really doesn't seem very practical for me.
Keeping that in mind, would a telescopic stabilizer kit be worth looking into? Seems like it would be a PITA adjusting those turnbuckles, especially in the winter.
Something like this: https://messicks.com/parts/k2561-38300fr
4,123
2,815
It's up to you to decide if you will use it. A 3PH QH and a Hydraulic top link is a better buy for me than changing turnbuckles to telescopic stabilizers.
hodge
Nov 19, 2010
2,960
531
Love, VA
I build telescoping stabilizers for BX tractors, they are heavier duty than the Messicks version, similar price range shipped ($7 difference), and mine are warrantied for 1 year. If interested, PM me.
Mustard Tiger
BX23S
Jun 26, 2025
95
223
Pacific Northwest
But if you’re regularly switching between the backhoe and other attachments, isn’t adding a QH another kind of unecessary and time consuming step since you obviously cannot use the backhoe and QH at the same time?
6,650
The extent of my experience operating a BX is limited to driving one around a dealer lot for approximately 3 minutes. I have, however, used turnbuckle/chain stabilizers, fixed length flat iron stabilizers, variable length rod stabilizers, and telescopic stabilizers (obviously on a variety of tractors). Currently have telescopic on my L.
If you want ZERO play in the 3 point, OEM won’t do that, at least not the ones on my L. There’s a slotted section that intentionally gives a pretty fair amount of play. The holes other than the slot don’t give much, but still a little, as in probably the 3/4” total play but I’ve never measured. IMO a 3 point hitch isn’t designed for zero side to side play. For example, I’ve had fewer repairs to my bush hog since changing to the slots in the stabilizers instead of the holes. The slots let it move a little when it inevitably hits stuff, and I prefer that few inches of movement to the alternative of something bending.
I’ve seen a few folks crank down on their turnbuckle/chain stabilizers to keep everything “perfect”. I think that’s not useful and setting up to bust something, but if that’s what you want, it ain’t happening with OEM telescopic stabilizers.
Personally, I think the telescopic is a significantly easier and faster to use than the other types I’ve dealt with and it’s at least as effective. Obviously, that’s an opinion, not a fact.
BTW, I don’t have a backhoe, don’t have a quick hitch, and switch 3 point implements routinely. I’m aware quick hitches are extremely popular. Maybe I’ll get one someday, but not today. YMMV.
JonM
Nov 29, 2024
275
662
wisconsin
a quick hitch goes on and off super easy with three pins. once you set the three point you dont need to jack with it for each implement.
i run a backhoe about 10% of the time. most of the time ive got a mower or seeder or just a weight bucket back there.
if you only run one implement its easier to attach a qh that jacking around with lining up three pointa on implements
ive got telescoping arms as well waaaay better than turning ones.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
I like the telescopic stabilizers a lot more than turnbuckles. When swapping implements it's a simple matter to pull both pins and the lift arms are free. Takes longer with turnbuckles. Same with hookup. Just drop the pins into the appropriate holes and you're ready. I bought a Cat1 QH many years ago and never installed it.
4,123
2,815
Yes and no. I'm trying to set up all my attachments to be compatible with QA including PTO shaft length. My QA pushes the attachment out about 4-6". It also gives me a little extra ballast weight.
Trying to line up the lift arms to match the attachment pins is a PITA with a hydrostat machine with a cab.
chim
Jan 19, 2013
3,278
2,976
.....................Trying to line up the lift arms to match the attachment pins is a PITA with a hydrostat machine with a cab.
That's what I thought till I simply flipped the rear window up and leaned back a little :)
ejb11235
BX23S, Braber BBR4G 4'BB & LRM5G 5' rake, Redline 48" rock bucket, PFL1242
Jan 20, 2022
486
374
Seattle, WA, USA
When I bought the 3PH for my BX23S, I took one look at the turnbuckles and said "hell no", and went straight to telescopic. I literally never used the turnbuckles. Eventually I also got some Pat Quick Hitches too.
Remember that the BX's can't lift the implements as high as with bigger tractors. It's not turned out to be a problem, but there have been times when I've wanted to get my landscape rake up and over a pile and I can't because I can't raise it high enough. This weekend I bought a nice rear blade and was very excited, but I had a moment of panic when I thought maybe the 15" mold board might create problems for me. It seems to ok, but there was an "oh shit did I screw up" moment.
6,650
If you don’t already have a hydraulic top link and you want a bit more clearance for this type thing, it’s something to consider. Pulling the toplink all the way in with the lift fully raised gives more clearance than simply raising the lift. I’ve found that particularly useful raking leaves with pine straw rake, crossing obstacles between fields with brush hog, and use with box blade and back blade.
ejb11235
Jan 20, 2022
486
374
Seattle, WA, USA
It might not be and here's why ... it's possible that you could build a platform to set the QH onto that holds the drag arms (or whatever they're called) and toplink while you hook them up to the tractor. I'm getting better at installing the 3PH onto the tractor, but
I've been known to do that "manually" ... shorten the top link. Believe me, I would really like to get a hydraulic top link oh man ... but first I need to get rear remotes. Sure wish the Kubota rear remote kit fit the BX23S :-(
