needing a hand with the wiring of an aftermarket combination switch
Kevinbou
other - AC Cobra build
Jul 5, 2025
Australia
Hi All
I am building an AC Cobra replica in Australia and am using an aftermarket combination switch that was designed for a Kubota harvester (picture attached) .
Doies anyone have experiance with these switches and could help identifing the purpose of each of the nine wire elements? Have run a multimeter over the wires to have a guess at what combination provides an output but still not sure i have this correct.
5,672
years ago someone posted a link to the manufacturer of those switches. There are several versions BUT they also listed the colours/wiring for them.
I know the connector is a Sumitomo, according to the BX23S WSM.
Kevinbou
Jul 5, 2025
Australia
Thanks for that. I dont actually have the connector plug only the wires. Will have a go searching. Thanks for your help
NorthwoodsLife
Oct 15, 2021
1,225
1,205
Wisconsin
AC Cobra? Beautiful car!
Shelby in the states.
Good luck with your project.
3,181
1,602
The Kubota part number is K7711-96130. This switch is used when adding the optional turn signals to an RTV-X1100c, and others.
It looks to be the same switch.
Kevinbou
Jul 5, 2025
Australia
Mate, thanks so much this is just what i am after, however when i print it its so small and when i enlage it (on screen) all the detail is gone. Do you have a higher resolution version?
5,672
curious, I 'right clicked copied',saved to desktop, used IRFAN to open it , could see it OK,fine even at 217%.
Kevinbou
Jul 5, 2025
Australia
Yep. thats the way to do it. I initially clicked on the message thumbnail rather on the attached file. Thank you for your help
