Firewood Moisture Meter
NorthwoodsLife
Oct 15, 2021
1,411
1,473
Wisconsin
I am looking to buy one and any advice would be appreciated.
These range in price from $10 up to the sky.
Thank you.
Be well. Tractor on.
Eric
Workerbee
Zd21
Mar 1, 2020
351
217
MN
Is that something for the guy who has everything? I can’t really imagine why one would be needed.
4,060
If diesel won’t get it going…. it’s still too wet….? 🤓
Reactions: 6 users
NorthwoodsLife
Oct 15, 2021
1,411
1,473
Wisconsin
I cut and store firewood.
Had a couple trees fall and trying to figure out a way to store the splits and rounds for best results.
One tree appeared to be dead, the other, not.
NorthwoodsLife
Oct 15, 2021
1,411
1,473
Wisconsin
I own the $10 version bought on Amazon. I works great.
Thank you.
I just watched Gordy (GP Outdoors) and ordered the TS 630 that he somewhat tested. We will see how it goes...
bbxlr8
Mar 29, 2021
448
309
Eastern PA
Same - I found I used it a lot at first for the knowledge and maybe the novelty? I am on Arboristsite wood burning forum and went with one of the recommendations over there (cheap but decent).
It is pretty good if you have a lot of wood you don't keep track off and note that sampling/testing technique is a factor w/ any of them. I find that the look, weight and feel of any given split or round is best. Of course, wood type, storage conditions, and weather are wild variables in my neck of the woods :p
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,447
1,743
Kalamazoo, MI
I have the General one and use it whenI buy firewood for camping to see if the vendor is screwing me.
WFM
L3800
Apr 5, 2013
1,573
1,051
Porter Maine
There are several loggers local here that sell klin dried firewood.
I've heard there is a certain 'content' of moisture where they can sell it as dried from the kiln.
Of course it costs money to dry it. So they want it right at whatever the rule says it's dry.
I don't own a meter but it would be cool to have. I might go look during Amazon days.
WI_Hedgehog
Apr 24, 2024
1,113
1,615
Milwaukee, Wisconsin, U.S.A.
I do landscaping for a hobby and cut windfalls--usually for firewood, so "close is good enough." If I were building tables (woodworking) I'd buy a $500 or $1500 unit that samples deeper and more accurately, but for burning or turning wood bowls "close counts."
TopTes Digital Moisture Meter TS-630
John T
2017 BX23S
May 5, 2017
1,239
768
under a rock
yeesh, what's wrong with cut ,stack, burn 2 years later method ?
re: 'kiln dried firewood' HAS to be expensive to buy
I agree, that's what I do. (or try) I like to be ahead 1 season....
I always order more (tree length) logs than I need.... I cut them in halves and stack them ..... until I see what I need for the next winter... they are ... maybe 70% dry...
by the time I buck them up and split them in the spring.... I'm good.
I actually got behind on things a few years ago.... and had to buy 2 cord.... just to be safe... I bought the moisture tester to make sure I wasn't getting my pants pulled down.
also works good if you cut slabs .... it's nice to know where your at before moving forward on a project.. / finish etc.
Also, these moisture testers have a LOT of other uses such as testing drywall if you are buying a house / especially a basement.
you can also test new concrete to make sure it's cured before sealing or applying pressure...
5,188
$18 on Amazon, with very good reviews
