L2950 broken axle case
Zekepup
B2410, woods backhoe, finish mower,box blade ,boom pole, old L2950
Dec 8, 2014
22
Suwanee georgia
I broke the left 4x4 axle case on my l2950 where the tie rod connects. I believe this is cast iron. Has anyone had success in having this welded? If not recommendations on who might have repair parts
3,143
Yes that is cast iron. It can be welded but that would be a difficult job and then require some machining. I think I would take the picture to a machine shop and see if they could repair it somehow. I have no clue how but they may be able to clamp it together with some bolts!
You can contact Lance Newhall (@007kubotaguy) and see if he has that at his salvage yard
11,222
Breaking it have anything to do with new tires?
That's an Incredibly hard part to fix.
Try Lance above first, then your next option below.
Zekepup
Dec 8, 2014
22
Suwanee georgia
Thanks the front tires have been on for a while. I take good care of the old tractor and really just do drive way maintenance. I had been using a box blade and then took a lunch break. Started to back out and finish …. Pop….. she snapped. Now to source all the needed part. A friend said check out Cross Creek tractor. All other help appreciated.
Zekepup
Dec 8, 2014
22
Suwanee georgia
Thanks
Zekepup
Dec 8, 2014
22
Suwanee georgia
I have checked all of the contacts and no one has this part. The one that Allstate had listed,is,no longer available. I have to continue the search. I got to have my old tractor up and running as soon as possible
11,222
Find a local welder that can weld cast.
The keep and eye out for a good used part.
07wingnut
274
123
Clearwater, BC, CA
On an 885 CIH tractor the lug that holds the 3pth arm restraining chains snapped. A local welder came and welded it, took about 2 hours, first to grind and then to heat the whole area, then welding, bit by bit, with cooling in between. After that, he welded a steel bar around the assembly. It held till the tractor was sold years later. In your case, you would have to disassemble the part, because the heating would destroy all the seals in that area and all that oil in the case might get hot enough to ignite.
Zekepup
Dec 8, 2014
22
Suwanee georgia
Thanks for all the reply’s. I have called every salvage yard I could find and no one has that part. I am on every list possible. I am taking it to a welder and at least try to get it back in operation, but of course they cannot guarantee it will hold. So if anyone ever hears about parts for the L2950 please keep me in mind.
rbargeron
Jul 6, 2015
1,185
262
western ma
Getting good strength in a cast iron part by welding is very tough to get right - and because of heat-induced weakening of the iron's crystal structure there's only one chance to succeed. I'd go for a re-design instead where a bolted block is added the casting by machining a new flat surface in the area where the breaks are.
Looking at your picture of the broken "ear" I'd take the part to a skilled machinist. That side of the casting could be milled with a new vertical flat area, with a couple of tapped holes in the thickest area for bolts. Then a short piece of thick steel angle iron could be made for bolting to the machined surface, with 2 holes for horizontal bolts into the casting and a hole for the tie-rod. Look for somebody with a milling machine (lots of old Bridgeports out there) who does machinery repairs. The new steel attachment piece could be angle iron or a solid block. Keep it compact so the wheel can still turn to the right ok.
Here's a rough sketch of the idea: (improved 7/11) Need to disassemble the gear housing so the drilled holes can go thru. Use grade 5 bolts - about 1/2" (13mm), trim them so they don't stick out inside the housing and use sealant. For full range of motion, the block's corners may need shaving. Should be stronger than new.
7/14/25 - couple more thoughts: maybe once there's good surface to bolt to, try mocking up a couple versions of the new block in wood or something easy to shape ?
Finding a clever machinist will be key - but anybody who still has a manual milling machine will be a great starting point.
Zekepup
Dec 8, 2014
22
Suwanee georgia
Thanks
Zekepup
Dec 8, 2014
22
Suwanee georgia
Well I thought I had found one , but it came from an earlier serial numbered tractor and would not work.The part I need is 35060-43826… was excited , but now back to the search. Just darn….
Zekepup
Dec 8, 2014
22
Suwanee georgia
Zekepup
Dec 8, 2014
22
Suwanee georgia
Well I am back. I had the part welded and it lasted for a while then broke yesterday. I had found on from an earlier l2950 that bolted fine but I found out that there were changes made between earlier and later serial numbers. The tie rod o-ending is smaller on the older style than the newer one. The opening is almost 4mm smaller. I was wondering if I could drill and ream the opening to the larger opening.
the old tractor is in good shape over all and I need to get it back on the job.
any help would be appreciated
thanks
11,222
If the only difference is the hole size then sure why not drill it out.
I would suggest getting the right taper ream to do it.
And keep it cool while doing it.
Note: I looked at all the supporting / attaching parts for both of the different housing numbers, and there is no changes to any other parts, so you should be good to go.
3,143
Perhaps leave it with the smaller (stronger) hole and use a newer version tie rod end??
11,222
Smaller is the older version.
Down sizing the joint is not a good option.
Old version of the steering.
New version of the steering.
Zekepup
Dec 8, 2014
22
Suwanee georgia
Wolfman,
I was wondering is there is a way to adapt the older smaller tie rod to screw into the newer style steering arm ? I am glad you said there were no changes between the older and newer gear cases other than the the tie rod size. I have looked for a replacement case but no luck. I sure hope I can use the one I have as it was not cheap either. Other than trying the milling a new steel block as stated above, the options are new case, try a different repair on the original of find a way to make the older style work on the newer style.
thanks for your help and if you have anymore ideas.
Zekepup
Dec 8, 2014
22
Suwanee georgia
You could get a replacement end and turn it down to fit the hole.
Or you could get the smaller end and weld it to a Rod nut and use that.
I think I am going to try and go with welding the smaller tied rod end in the newer style steering tie rod. That way I would not remove any material from the tie rod ear. I wonder if anyone has ever done this repair. I sure wish there was a replacement smaller tie rod end that would work and screw on, wishful thinking I know.
When looking for the original case it seems as if the left side breakage was not an uncommon issue with this tractor as several people were looking for the same part on the same L2950.
thanks everyone for your help and advice. Let’s get her back on the road.
