Another wheel spacer question...
Mustard Tiger
BX23S
Jun 26, 2025
95
223
Pacific Northwest
Took delivery today on a new BX23S. Entire property is on a slight grade on 2 acres. One of my neighbors also has a BX23S and has put 500 hours on his over the last three years and loves it, and was one of the reasons I went with a Kubota.
I spoke to the manager of the dealership about wheel spacers and he said that Kubota only makes 5/8" spacers and that's all they recommend and said that any wider can lead to leaking seals. This contradicts pretty much everything I've read online, and even a Kubota dealer mentioned on their Youtube channel that they've never seen any issues with people using wider spacers up to 3" (I believe it was Messick's).
I'd like to add some 2" spacers. Many says they can feel a difference ins stability with the wider stance, and spacers are cheap. I don't want to void my warranty though, and don't really see the point of a 5/8" spacer.
Guessing the consensus is going to be that I shouldn't doo it since my particular dealer said the warranty will be void if you go with anything wider than the 5/8" OEM wheel spacers.
10,032
Do it, then if you have any seal issues, (which is highly unlikely) pull the spacers off before you send it to the dealer. ;)
2,970
I highly recommend spacers - I had them on mine for 12 years (BX25d) zero problems and seen a huge difference too.
arml
B5100e BX2200 JD455AWS G1800
Jan 27, 2022
235
251
Pennsylvania
I'm wondering if 2" spacers will clear the mower deck?
3,811
Do it.
If you have any problems…. take it to Messicks and see if they’ll warranty it for you… :cool:
