L2195A Gear Oil change
dfixit1
L4240HSTC-3
May 17, 2019
143
United States
Changed the gear oil in both gearboxes, reduction box and final drive box and thought I’d post pictures of it. The reduction gearbox has a drain, small metric allen head and holds 24 ounces. The final drive gearbox doesn’t have a drain so I improvised (shh don’t tell the wife) to remove the fluid, it held 12 ounces. I used Mobil Delvac Synthetic Gear Oil 122035 75w90 for refill from Summit. I always label with date, oil and capacity for future reference, no guessing!
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
111
41
NH
I know this an old post but I'm hoping someone can answer a question for me.
So it appears there is no drain plug for the gear case so I will need to siphon it out (relax honey I will use the vacuum pump not your baster). When re-filling the gear box do you fill it to the bottom of the fill plug hole?
What is the recommended gear oil?
Ok, that was two questions.
5,176
What does the owners manual say about changing the oil?
3,232
1,841
Nvm
imarobot
Apr 18, 2025
111
41
NH
Manual says to check every 24 hours and add as needed. No mention of when or how to change it.
imarobot
Apr 18, 2025
111
41
NH
Thats what I suspected. Like many implements it does not need to be routinely changed - just kept full.
Ever??? This thing is 12 years old
imarobot
Apr 18, 2025
111
41
NH
I wish everything was like that!
