GL281 D1503 Metal vs Graphite head gasket
MichaelQ
Kubota GL281 D1503
Jun 25, 2025
France
I'm replacing the head gasket from my D1503 engine with the metal gasket.
Could someone tell me if I should replace the little blue o-ring which came off the small pipe under the thermostat in the cilinderhead? In the metal head gasket there is a small hole for the pipe but no real place for the o-ring and the original gasket had a large hole which is big enough for the blue o-ring.
Best regards, Michael
2,118
Yes you should replace that o-ring.
Most people that have experience with head gasket replacement always recommend that the head gasket is Kubota (OEM) gasket, not an aftermarket gasket.
8,802
If the replacement head gasket does not match the OEM head gasket your going to have problems.
Most aftermarket head gaskets are too thick.
And yes you must replace the O-ring for the Oil pipe with the same kind of O-ring, do not go to a black or green O-ring as they are too stiff and will not let the head seal properly.
MichaelQ
Kubota GL281 D1503
Jun 25, 2025
France
Thanks for your reply,
I got the old gasket off but can't find the code for a replacement gasket. Can I simply measure the old gasket and order the same thickness?
Also I found this thread where you say this: The only gasket they list for your motors application is 16467-03310.
Could it be that the same applies to my GL281 as it's a model after the L2900 with the same engine?
8,802
Give me the model and serial numbers,they are stamped on the block facing up just to the outside of the Injection pump.
8,802
MichaelQ
Kubota GL281 D1503
Jun 25, 2025
France
MichaelQ
Kubota GL281 D1503
Jun 25, 2025
France
thought I'd show you some pictures.....
And it's running very smooth now so I'm happy. Thanks for the assistance!
