LX2620 bucket differences
AOW162435
'25 LX2620 / '79 B7100 / '03 JD x595
Jun 16, 2023
196
Ellicott City, MD
I've read conflicting info regarding this on various forums and hope that someone can clarify here. For the LX2620 with the LA535 loader, are there differences between the two buckets offered (other than the width)?
The 60" bucket has a decal on the rear that references 'light material' usage, and I've read that the construction of the 54" bucket is more robust.
My use for this loader will be to move gravel, large rocks, dirt, etc. Not scooping sawdust on a concrete floor.
Would really like some clarity on this, as I'm not concerned about the rear track width exceeding the bucket width.
Andreas
10,128
For dirt work stick with the 54" bucket. ;)
10,128
Both, the 54 is build a little heavier and because of it's smaller size it can better handle heavy materials.
6,450
60" bucket works fine for me...and I use it hard. It'll lift a full bucket of whatever you have in it.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
924
898
E.
a slightly different model but i too survive with the larger bucket while moving mixture of light material (fluffy snow) to heavy dense material like pea gravel.
But I and my team players are careful and kind to our equipment.
For sure the 54" will take more abuse but would guess the 60" outsells the 54" for many reasons ranging from mostly preference to need.
For a rental fleet hands down 54" to handle rookie users and abuse. For an occasional homeowner with reasonable skills 60".
re: 60" no need to slam into piles or stumps and if handling heavy material simply fill bucket to 80% and Bob's your uncle .
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
72
60
Lakes Region, NH
I have that same 60" so called light material bucket on my LX4020. I added a bxpanded piranha tooth bar to it and it is plenty strong digging and carrying a full load of stone or dirt. The LA545 loader on my tractor has only a very slightly higher lift capacity than your LA535 loader so I would not worry about that if you go with the 60" bucket, as long as you have loaded tires and a good counter weight on the 3 point. However the piranha tooth bar does greatly reinforce the bucket cutting edge so I can't comment on how well the original cutting edge would hold up on its own.
Nomore67
Currently own- LX4020, B2601, IRE20 (mini-ex). Previously owned- BX1870, B2601
Apr 28, 2019
31
40
Minnesota
I've had (3) 60" buckets, two on B2601's and one on a LX4020... I've used / worked them all in various ways, and have never had an issue with any of them. *I say used / worked (maybe even hard), but not 'abused'!
'If' I were buying another machine tomorrow in this size tractor I wouldn't think twice about another 60" bucket. -just my two cents....
3,606
2,209
I think the 54" has an optional bolt-on edge, which I'd recommend for your usage. If you want the 60" bucket, you'd need an aftermarket edge, either a piranha like @bobnic mentioned or a straight one. In either case you'd have to drill the bolt holes.
Petey
LX4020HSDC
Jun 6, 2025
Enterprise, AL
Hello there,
I'm getting the 54" bucket on an LX4020 series, but do not yet have it in possession (it's on order). I'm interested in going ahead and purchasing the Piranha tooth bar, but need someone to confirm the exact internal dimensions so I can make sure I order the correct size bar - can anyone provide any details on the correct size tooth bar for the 54" bucket that comes with the LX 20 series, I think bucket model B2371?
For reference, here are the instructions on measurement location for the bucket according to BXPanded, if anyone has this bucket and can confirm dimensions: https://bxpanded.com/assets/images/How-To-Measure-Bucket.pdf
Petey
LX4020HSDC
Jun 6, 2025
Enterprise, AL
That is certainly interesting, and misleading on Kubota's part. I chose the 54" because I was under the impression the "light material" bucket wasn't made as tough. I may contact my dealer and see if it isn't too late to change on my order, since it's an easy swap.
I still need to know the exact internal dimensions so I can prepare to order the correct sized Piranha tooth bar.
bobnic
Mar 7, 2025
72
60
Lakes Region, NH
If you decide to switch to the 60 inch bucket, I have the 60 inch bucket on my LX4020 and I ordered and installed a 58 inch Piranha tooth bar on it. I am very pleased with the both the bucket and the tooth bar.
Petey
LX4020HSDC
Jun 6, 2025
Enterprise, AL
Thanks for the info! I'll check with my dealer and see if it isn't too late to switch. I'm sure it shouldn't be much trouble. They told me my order would be nearly 3 months out...
4,691
I seem to recall something about a "square back" Vs. "rounded back" bucket design.....One being better than the other?
I didn't pay much attention though.
One thing that I found out was that having a "tooth bar" was a "massive improvement" when digging into a dirt pile.
I did a "before and after" dig test, and it wasn't even close.
The "tooth bar" addition looked like probably a 50% increase over the "non-toothed" bucket.
Mine is "home-made" and I specifically made it simply because I thought it would "look cool", .......but man it really helps when digging, and it's easily removed if I decide I need the "smooth bucket" for some reason.
