are rear wheels handed
B2710HSD
B2710HSD belly mower flail water bowser logging bench
Aug 12, 2011
10
CHEPSTOW UK
Just about to swap some wheels between two of my kubota tractors and noticed a kubota part number label on the back rims with an indication of handedness i.e. one wheel is marked left and the other right. Can anybody shed any light on this? I initially thought the rims might be a different offset but searching the parts diagrams seems to indicate the rims are the same but the sticker differentiates the handedness. Could be for agri or industrial tyres which have a direction of rotation but i doubt it makes much difference to grass tyres.
SDT
multiple and various
Apr 15, 2018
3,399
1,177
SE, IN
Labeled according to how tires are mounted.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,972
2,428
Near Lancaster, PA, USA
As far as I know, my wheels are bi-directional. If you're concerned, look at the shape of the lug bolt holes.
2,577
As far as I know, all tractor tires are lugged to be directional- even turf tires
Survivor
L2501
Jun 8, 2025
46
41
Yeah, I think that label is just denoting which way the tires are mounted from the factory.
I suspect so that some dumb technician won't put them on the wrong way after the crated tractor is delivered from Japan.
9,877
They are the same rims.
No difference in offset or any anything else to worry about.
JonM
Nov 29, 2024
162
342
wisconsin
the wheels are the same the tires are handed left or right excluding most turf tires.
9,877
The tire are not "handed" they will mount right and left.
They are directional on R1's, R2's, R4's, R14's and and some R3's.
JonM
Nov 29, 2024
162
342
wisconsin
once they are on the rims they will be backwards if you swap em is what i meant. which is probably why the wheel assembly is labeled.
