mower deck safety switch
Kubota 1850
Kubota 1850, John Deere X590
May 21, 2022
Pa
mower deck wont shut off if you are off seat. How do i troubleshoot?
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,587
1,824
Near Lancaster, PA, USA
Of course keep your body parts clear. Start with the simplest things. Does the switch itself move as it should? Does it switch power as it should?
Kubota 1850
May 21, 2022
Pa
when I used to get off the seat with the tractor running and iwould bump the implement lever it woud try to shut off the tractor. Now it wont.
5,686
1st get the wiring diagram out of the WSM for your Kubota. Without that you'll spend hours and may not find the reason. Post which model you have, there may be a WSM at www.kubotabooks.com.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
268
268
Amsterdam, NY
The mower deck shouldn't shut off - the tractor (engine) should shut off.
The tractor has an Operator Presents Control (OPC). The safety switch in the seat is part of that system. If the PTO is engaged or you're pushing on the pedal to go forward or backwards and get up off the seat in engine should stop. Check the seat switch first.
I didn't see a BX1850 WSM on K-books but there is a WSM for the BX1860 which is the next model starting in 2009. The electrical diagram should be similar enough to trouble shoot.
