3rd function flat face couplers and grapple
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
423
660
NH
Tried hooking up new grapple to 3rd function connections ( flat face couplers) on L6060 loader. No joy, The Homestead Implements grapple connections are 1 /2 inch flat face. They do couple to each other just fine.. The 3rd function kit appears to be smaller diameter? It is not a pressure issue since we bled off the pressure by loosening fittings. Do folks know what the " standard" 3rd function fitting specs are typically? Of course,, it's the weekend and dealer is closed,. I can get pics and measurements later today.. Thanks gang.
6,737
There is no standard but on a tractor of this size 1/2" couplers for a grapple are overkill. If the tractor side is smaller my guess is 3/8".
Gaspasser
Dec 16, 2023
423
660
NH
Thanks Dan. It seems I need to become a Kubota mechanic to be able to use my tractor efficiently, lol. So if I wanted to change out couplers and shoot for future compatability with other implements in the future, sounds like I should keep the 3rd function couplers as is and change out the ones on the grapple.
I'll call dealer Monday and see what makes sense. Thank you again. Folks like you make this forum a great resource.
Old Machinist
May 27, 2024
630
743
NE FL
If it were mine I would change the tractor to match the fittings on the grapple. I think the 1/2 inch flat face IS the norm for a skid steer due to them changing implements under pressure.
Depending on the brand of your third function the hose connecting to the fittings could be anything. Kubota loader hoses tend to be JIC flare. You will have to adapt whichever way you go so you will need to pull a fitting at whichever end you want to change and determine connection type and size then go from there. Plenty of type and size charts online to help in that determination but first you have to pull a fitting and go by appearance and size.
6,737
He has a 9 GPM tractor not a 20-40 GPM PM skidsteer. A 3/8" flatface is good for 12+ GPM which is more than his tractor can produce.
Old Machinist
May 27, 2024
630
743
NE FL
My point is the flat face is supposed to be easier to connect than the ISO.. Doesn't matter if your connection is more capable than the system . He only needs to change one end or the other and it will work fine with oversized fittings.
6,737
I think you have things a bit confused.
His loader does not have ISO 5675 (agricultural) couplers on it. It has ISO 16028 (flat face) couplerd on it.
The problem is the body size (3/8??) on the loader is smaller than the 1/2" couplers on the grapple. Its both easier and cheaper to change the couplers on the grapple.
Old Machinist
May 27, 2024
630
743
NE FL
I guess I did misunderstand the problem. He didn't specify the third function connections were also flat face. Just that they were smaller.
He still needs to remove one of the fittings to determine the line connection to get the correct fitting and adaptors.
Gaspasser
Dec 16, 2023
423
660
NH
I grabbed some measurements and pics today. For me, the question is what connectors would future 3rd function implements likely have? I am happy to change out either end hoping to be compatible. First pics are tractor side. 2nd set are grapple side. Thanks as aleays for your help gentlemen.
10,480
You can read the number on the coupler stamped label.
6,737
The tractor side is 3/8" body size and grapple side is 1/2" body size.
Most vendors let you choose what you want on the implement. I have already expressed my opinion. Unless you also have a skid with higher flow hydraulics 3/8 is appropriate for a compact tractor with <10 GPM hydraulics.
Gaspasser
Dec 16, 2023
423
660
NH
Thank you. Appreciate the details. So these connectors are classified by outside diameter? I'll hit dealer first thing this morning and get grapple side connectors. Amazing how many variations there are and how much time is spent hooking and unhooking implements. One would think that there would be a common standard. Kind of like my Fisher snow plow with the highly touted "minute mount" system. Seems like " hour mount" is more like it, not including the profanity laced tirades. My kingdom for a level concrete floor equipment shed!
6,737
Hydraulic couplers are classified by "body size" which is indicative of their "nominal" rated flow rate. All the industry standards do is establish the physical dimensions for the male plugs. And even that is limited to the mating surfaces. The rest is left to the OEMs that actually make the couplers.
Old Machinist
May 27, 2024
630
743
NE FL
Like I said, you still need to know what the line/hose connection is. They are most likely JIC flare but what size? Other connection options are NPT, ORB, or ORFS so there's that?
In other words you may need fittings and adaptors.
My MTL grapple arrived with 1/4" hoses that had 1/4" JIC ends and 1/4" JIC to 1/2" ORB adaptors and 1/2" AG quick connects. I switched it to 3/8" ISO quick connects so I needed adaptors for 1/4" JIC to whatever thread those were. I forgot what thread my quick connects I bought were.
2,765
As North Idaho Wolfman stated just write the numbers down on the couplers. So you should be able to get four numbers.
Take that to your supply vendor and tell then to get you a similar part that is smaller size. Then show them the numbers from the coupler halves that you want to continue using. A hydraulic shop should be able to do that easily, a tractor supply shop may be confused.
6,737
Thats fine but with flat face couplers you dont need OEM numbers. All you need is body size and hose port type (NPT, ORB, etc). Kubota and the vast majority of other OEMs use couplers with female NPT ports.
Old Machinist
May 27, 2024
630
743
NE FL
I haven't seen any NPT connections on my Kubota, John Deere, or New Holland. The JD and NH mostly have ORB to ORFS and the line terminations on my Kubota are JIC flare.
6,737
I cannot speak to JD and NH but I am quite familiar wirh Kubota. Kubota generally uses couplers with female NPT ports and hoses with JIC female swivels. There are exceptions.
For direct hose connections the hoses have male NPT ends that screw into the couplers with PTFE tape.
The couplers shown in the OP's picture are bulkhead mounted using a male JIC to male NPT bulkhead fitting. The hose has a female JIC swivel that attaches to the male JIC side of the bulk head fitting and the coupler has a female NPT port that screws into the male NPT end of the bulkhead fitting.
Couplers on loader valves have female NPT ports that connect to hoses with male NPT ends. Valves have female ORB ports, valve mounted nipples have female NPT ports, and they are mounted using male ORB x male NPT adapters.
Aside from the high dollar remote couplers and sectional valves on the larger M series machines I have never seen Kubota use JIC or ORB couplers. I really wish they would but the dont.
I am not from Missouri but please show me all of these JIC/ORB/ORFS couplers on your Kubota machines.
Old Machinist
May 27, 2024
630
743
NE FL
Follow up with what you needed to change the fittings on the Homestead Implements grapple. Might help someone else in the future.
For anyone ordering a grapple it's a good idea to figure out what is on the tractor and ask the grapple manufacturer to match it before it ships. It is frustrating to get a new implement and not be able to use it off the truck.
Gaspasser
Dec 16, 2023
423
660
NH
Ok gang. Sorry for delay. Been clearing wood lot with rented excavator, my tractor and my mini-ex since we finally have had some non-rainy weather. Had some 90+ degree days which is not typical in NH but powered through. As for the grapple-tractor coupler compatability issues, I went to dealer. Had measurements for both sides but apparently needed more information for the coupler to hose connection on the grapple side. Since I didn't have this info at hand, and didn't want to waste a few hours driving back and forth again, went with changing out the tractor side 3rd function couplers with 1/2 flat face. Asked dealer what the trend is with future possible 3rd function implements and he stated it was a crap shoot. So spent more than I needed to but saved wasted time. Appreciate the advice as I figured this out. It is surprising to me how much time is spent and compatability issues, pto hookups, implements, hitching. etc. Almost a job in itself some days. Thanks again!
