Drum mower experiences and possible hacks..
icehorse
L3901, box blade, tedder rake, mini round baler, drum mower, rotary cutter, misc
Aug 10, 2022
156
30
I recently purchased a 53" drum mower from Titan. I'm still working with them, but my conclusion is that they've been making non-PTO gear for a while and they're pretty good at that, but that they're new to making PTO gear? The reason I say this is that for the last 3 months all I've been hearing from them is that they don't have any parts for the mower they sent me. That seems really bad to me. Sigh.
So I got about 4 hours of cutting done and then the gearbox broke. They told me that "maybe" they will have replacement gearboxes available in 5-6 weeks, yikes!!
So a couple of questions:
1 - I've been looking for a 3rd party gearbox. Two PTO spindles, set at a 90 degree angle, rated for 40 hp. I've found a few 90 degree gear boxes, but they aren't PTO spindles. Does anyone know of 3rd party gearboxes?
2 - Our fields are just two bumpy for the drum mower the way it's set up. I've thought about adding a hack where I suspend it a few inches above the ground. But it seems more common to add a spacer kit or lift kit so that when the bottom of the mower is on the ground, the blades are a few inches higher off the ground. Any thoughts or experience on this?
KSCessnaDriver
BX1500D, L4802
Mar 12, 2025
15
NE Indiana
No idea in the gearbox. If it’s too bumpy, does slowing down while mowing seem to help? My fields aren’t perfectly smooth, but the sections that are worse in terms of bumps, I found slowing down helps a lot.
you can put a lift kit on a drum mower, but the bottom of the drum still has to ride on the ground.
icehorse
Aug 10, 2022
156
30
When I let it run along the ground it sort of flopped around, I know, not a great description. More precisely, the drums didn't stay vertical. I'm imagining that with a good drum mower, the drums sort of follow the terrain but stay pretty close to vertical?
What was your experience with how the drums moved as you cut?
One more question: Does it seem to you that the weight of the drums is somewhat held up by the arm, or is the total weight of the drums resting on the ground?
BTW, if I can fix the gearbox or get a new one, I also think I'll do some sort of lift kit.
KSCessnaDriver
BX1500D, L4802
Mar 12, 2025
15
NE Indiana
They’re tricky to get set up properly, in terms of being level. I’m not sure what adjustments your particular model has, but for me I watched the following video, and it does a good job describing how to get it how you want it.
icehorse
Aug 10, 2022
156
30
Yeah, I watched that video but it seems like my mower isn't anywhere near that sophisticated :(
As I mentioned, it just sort of flops around.
Let me reiterate a question I asked you after the fact in a previous post (my bad):
KSCessnaDriver
BX1500D, L4802
Mar 12, 2025
15
NE Indiana
the majority of the weight should be running on the drums, if I remember correctly, and that’s how I had mine set up to run
icehorse
Aug 10, 2022
156
30
I really appreciate you taking the time to discuss this!
I'm still not quite understanding this: On the one hand, I think we're agreeing that the drums should be leveled, and that that's done by adjusting the mower and the 3 points? But then if the drums are mostly supporting themselves, how and why does leveling make any difference?
In my case, the "arms" that extend from the 3 pt. end of the mower out to the drums are very loose, and I think that's by design. So the drums can tilt in every direction from upright, and the two drums are supported by one attachment point between them so that they can "float", left side higher then right side and vice versa.
In other words, I would say that there is a lot of "play" in my drums' alignment. I suppose that if everything is leveled, that means there isn't too much play in any one direction?
And it's also the case on my mower that the entire weight of the arms and drums are on the ground. There is zero support from the rest of the mower except maybe to keep it relatively upright.
KSCessnaDriver
BX1500D, L4802
Mar 12, 2025
15
NE Indiana
I looked up what you've got. It certainly looks a lot different than the European style drum mower. Of course, their goal was to build it cheap. I don't see how your model can ride the contours of the terrain, it looks very rigid. Probably works on flat ground, but hills, I'd hate to try to run that. You want the drums to be level, so that they're cutting level with each other, if you get them out of level, they'll scalp and potential dig into the ground.
I'd probably have to play with it in person to figure out how to set it up, but it may just not work how it needs to, to be honest.
icehorse
Aug 10, 2022
156
30
I'm upset with Titan. They have no parts, and basically no support, and I can't return it. I also don't feel good about pawning it off on someone else. So I'm thinking about how to improve it:
First off, I'm trying to get clear about how they're supposed to operate. Potentially the drums could move in 3 dimensions, so I'm going to use airplane lingo here. If we assume the tractor is moving forward, then potentially the drums could be capable of some combination of pitch, yaw, and roll.
Looking at a bunch of videos, it appears that none of them really yaw, and that makes sense to me. It also appears that they allow a bit of roll to conform to uneven ground. That also makes sense.
So it's the pitch that I'm focused on. From what I can tell, on a good drum mower, the drums aren't meant to pitch when in use. So that's what I think is true.
Oh, and finally, I think the good ones also allow for some vertical movement without any pitch or yaw.
Does that sound correct?
If so, then what I have to tweak is some way to keep the drums from pitching. I've got a few ideas, but I want to make sure I'm headed in the correct direction.
KSCessnaDriver
BX1500D, L4802
Mar 12, 2025
15
NE Indiana
The only "yaw" is the breakaway for if you hit something. Roll, yes, my design allows it to roll if needed. You would control pitch with the 3 point top link.
icehorse
Aug 10, 2022
156
30
I think we're agreeing here, but to verify - yes, I could still control pitch with the top link, but what I'm thinking is that it shouldn't pitch on it's own, while underway.
