Kubota Zero Turn ZD21F
BrianD
B7100HST-D, ZD21F Diesel
Jan 26, 2019
22
BURLINGTON
Hi All,
just recently purchased a ZD21 diesel mower that had a fuel tank missing. I bought a used one off of ebay and it was missing the fuel pickup tube. Does anyone
know what kind of pickup line it uses and is there a screen on the end of it at the bottom of the tank. The dealer couldn't find any parts for the tank other then the fuel gauge sending unit, they can't even get a whole new tank. Also does the fuel return line have a line off the bottom of the fitting that goes into the tank with a check ball on the end of it.
Thanks,
6,285
curious I found this at the 'parts finder' website, might be of some help ? I assume #060 is the fuel to engine, the bigger pipe , the return will be the smaller, #070. Do you have those 'right angled' connectors on your tank ?? Would think you only need a 'pickup' tube on the 'fuel to engine' ? Hopefully those that have or work on them will know..
BrianD
Jan 26, 2019
22
BURLINGTON
BrianD
Jan 26, 2019
22
BURLINGTON
Hi Greensvillejay,
I saw that too but, it doesn’t show the pickup line that is in the tank , thanks though for the suggestion
BrianD
Jan 26, 2019
22
BURLINGTON
Does anyone know what model Faria fuel gauge Kubota used for the ZD21, since it is No longer available. I have found some faria marine gauges that look a lot like just wanted to get as close to as possible
3,662
2,086
The fuel gauge has been superseded by part number K3211-61124
A new complete fuel tank is available, part number K3111-24004
The fuel return dumps right from the fitting; there is no tube.
The suction tube has a plastic tube that reaches into the lowest section of the fuel tank and has no screen on it. It lacks 1 1/2" to 2" from contacting the bottom of the tank.
BrianD
Jan 26, 2019
22
BURLINGTON
[/QUO
Thank you for the information on this, I have tried to find out via web searches and found nothing. I really appreciate your feedback
thank you again
