P Papalote New member Equipment Kubota M7060 Sep 8, 2023 9 1 3 Texas Jun 17, 2025 #1 I have a Z231 mower that the left side drive quit working. Is there a way to ck the hydraulic fluid in the drives? Thanks.
G GreensvilleJay Well-known member Equipment BX23-S,57 A-C D-14, Apr 2, 2019 13,263 5,912 113 Greensville,Ontario,Canada Jun 17, 2025 #2 quik chek.....look underneath and see if the case is gooey WET or dusty dry !
P Papalote New member Equipment Kubota M7060 Sep 8, 2023 9 1 3 Texas Jun 17, 2025 #3 It’s dusty dry. After it cooled off it works. Has happened a couple times before. Took it to the dealer and of course it was cool so they said there was nothing wrong with it.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 34,546 9,782 113 Sandpoint, ID Jun 17, 2025 #4
P Papalote New member Equipment Kubota M7060 Sep 8, 2023 9 1 3 Texas Jun 17, 2025 #5 Wolfman, thank you but the Z231 doesn’t have that part.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 34,546 9,782 113 Sandpoint, ID Jun 17, 2025 #6 Papalote said: Wolfman, thank you but the Z231 doesn’t have that part. Click to expand... While your Z231KW doesn't have that part, but a Z231KH and a Z231BR does. You're model just has a plug.
L lugbolt Well-known member Equipment ZG127S-54 Oct 15, 2015 5,506 2,213 113 Mid, South, USA Jun 17, 2025 #7 the little z231's have non-serviceable transmissions. Make sure the cooling fans are intact. Outside of that, it's probably internal.
P Papalote New member Equipment Kubota M7060 Sep 8, 2023 9 1 3 Texas Jun 17, 2025 #8 Thanks wolfman. Lugbolt, that’s what I’m figuring out. I blow everything off after I mow. I’ll check the belts too. Thanks again
