M8540 Flood Damaged
j.t.brownlie
M8540
Jun 15, 2025
New Zealand
Hi,
I have a M8540 that went through a major flood (a lot of silt deposits) and was fully submerged.
Replaced all fluids, filters ect.
Ran fine for about 6 months and now won’t go into gear and power steering is very rough. Understand the power steering, hydraulic shuttle and PTO engagement are all run of the same hydraulic line.
What will be my problem? Where should I start and what’s the likelihood of it being flood related?
Any help would be greatly appreciated.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,238
153
Coyote Flats,Texas
Welcome to this forum
I think it's a high probability that your tractors problems are flood related! Have you changed hyd filters lately? Have you checked hyd oil level lately?
3,871
2,518
Being submerged is the problem. There is a reason why submerged vehicles get written off and auctioned out of state far from the scene of the crime to unsuspecting buyers.
sunpyi
Algeria
It is probably related to the mud or silt that remained in the hydraulic circuit despite the emptying. I would start by checking the suction strainer, it may be partially clogged. A complete cleaning of the circuit and a change of the filter could improve things.
5,661
I'm betting you only changed the hydraulic oil and filter(s) ONCE right after the flood ??
As others have said, replace them all again. You also should disconnect hoses and manually remove the oil still in all cylinders( that's the messy part of the job). Right now every cylinder is 1/2 full of contaminated oil and the line. The more oil you remove the cleaner the system will be. Some( most ? ) guys just do a 2 round purge right after the 'dunking'.
Hopefully another round of filters and oil will get it 'up and running'.
Spam Bot
Windows Computer
Aug 3, 2024
Austin, Minnesota
Did you have insurance on the tractor? If so, did you put in a claim? If not, you will spend a significant amount of money or labor to restore the tractor to its original state. I used to repair flood-damaged cars, and many times, when there was silt in the water, we would perform a partial or complete disassembly of the automobile's mechanical parts to remove all the silt. A teaspoon of silt is enough to destroy engine bearings and any other moving parts on a tractor or an automobile.
Running the tractor without entirely removing the silt was a significant mistake, as it makes removing the contamination more difficult, since the contamination has now spread to components that might not have been damaged initially.
8,705
Check fluid quality and quantity and filters.
If all that looks good it's very likely that you coulld have damaged pumps.
j.t.brownlie
M8540
Jun 15, 2025
New Zealand
Hi,
Thanks for the reply’s. Oils have been changed multiple times and has been running fine until Hydraulics failed pulling a tip trailer.
The hydraulic pump does not sound right.
8,705
Wholy mud batman!
A pressure washer would really help!
5,447
2,139
I see this too often on SxS's too. Sit in the creek/river/lake/ocean for x number of days/weeks/months. It's just water, so let's just change the fluids. Right?
WRONG!
That water has mud, dirt, poo in it. It settles to the bottom of the container, the container being the engine, transmission, everything it touches, it settles into. You can change the fluids 2,000 times and never get it all out. The ONLY foolproof way to get it all out is to disassemble the "container" and manually clean it all out. If you don't want to do that, chances are good that at some point that dirt will dislodge from where it is currently and wreak havoc on stuff that is intolerant to dirt.
On the ATV/UTV stuff (and tractors too) the container (engine, trans, differentials, etc) has many nooks and crannies that the dirt can settle into. Over time it breaks loose and circulates throughout the engine. Sure I can change the oil 4 times on a Wolverine 850, and it stays clean for a while but sometime in the future, might be next week, maybe next year, it WILL start smoking, knocking, rattling, or just kick a rod out due to the dirt that broke loose and became sandpaper inside the engine (or transmission or front diff) They (engines and transmissions) have filters but they don't do much good when the dirt breaks loose while running and that dirt is slung around inside by the rapidly spinning crankshaft, which turns the oil into more of a froth and slings it up into the cylinder walls, camshaft, tappets, --and some of it gets into the lube circuit and through the head(s) and crankshaft and balance shaft(s) too, which usually destroys them. That's why I advise owners of SxS and ATV to avoid deep water. Whether they listen or not, is up to them.
That said, it's entirely possible that it's already done that. I don't mean to be the bearer of bad news but I think you've got yourself quite the project there. Now that it's been sitting that long with dirt/mud all over it, and inside it, you're gonna have a time of it getting it all off and out.
If it were me (and admittedly it is not), I'd have never bought it in the first place, and for some dumb reason I did, I'd have it cleaned off and sold in no time. I never ever ever ever ever EVER buy flood vehicles, and I won't take them if someone paid me to take them either. They are scrap to me. All of them. And I buy about 150 or so ATV/UTV a year, but I will not buy flooded/sunk ones. Just too much work for very little if any money to be made. Usually a loss, TBH.
