Turning the pumps up!
tractorstuff
25
Massachusetts
A friend of mine has a 2025r deere that he turned his hydraulic pump up a couple hundred psi.. can that be done on my b1750?
Does anyone have any experience pros and cons about the hydraulic pump turn up?
Also I had an old mechanical injection p-pump 12v cummins truck i turned the pump up a little (allowed rack to move more and larger fuel plate) can similar be done to a kubota injection pump?
4,117
2,812
Pimping your ride? Don't forget to paint flames on the side while you are at it to make your SCUT go faster.
Put a stack of pennies under the relief valve spring and your 1,400lb tractor will now lift 4,000lbs.
Rdrcr
Vendor Member
May 7, 2021
771
970
WA
BXpanded sells a shim kit to increase the loader hydraulic pressure. I’m not sure if it applies to your tractor model but, I believe the parts are universal, I could be wrong.
Just make sure you have proper ballast and don’t go overboard with increasing the pressure.
Mike
10,987
That motor was not "detuned" without adding something like a turbo, turning up the fuel will do diddly squat for more power.
JonM
Nov 29, 2024
273
660
wisconsin
wouldnt do it.
the hydraulics are set so you wont hurt the tractor or loader. upping that power gives it enough power to do damage.
just my opinion do what ya want
hodge
Nov 19, 2010
2,960
531
Love, VA
499860135_692021726863992_4764040814062856253_n.jpg 499925831_24273314252292846_2966510849506011369_n.jpg
From another site- both tractors had the hydraulics turned up. I know no other details, so it's no use asking. I'm just posting them to contemplate the end results.
6,283
dear oh deere....... green machines have 'split' personallties !!!
if you need more lifting power, buy 2 sizes up tractor OR move somewhere your current machine performs just fine.....
bootlegfab
L2501
Jun 11, 2025
N. Ca
I bought the BX kit with gauge and shims. Mainly to see if I was within factory spec or just below. I was 75psi below spec so a .2 shim was put in which brought it up to spec. Checked a neighbors 3301 with 500hrs on it and it was 150psi. Likely due to wear and tear. A .4 shim brought him up to spec. It was a noticeable on both tractors. The kit is cheap and easy to use.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
195
199
I have a friend who was a Powestroke tech at a Ford dealership. A 6 month old truck came in with a blown engine. The owner claimed he hadn't modified the engine.
After running a computer diagnostic, my friend discovered the owner had installed an aftermarket chip to up his horsepower.
The owner put the stock chip back in to try and hide what he had done.
Warranty denied, owner out several thousands of dollars.
Survivor
L2501
Jun 8, 2025
46
My dealer did all this for free under warranty. He came and hauled it to the shop and brought it home again, about 70 miles each way. I don't know about "quick and easy" but he said they had to pull off a lot of stuff including the fuel tank. And they did it all so I won't have them fussing about warranty violation if something worse happens later.
