Complelty lost looking for hitch components
Dranul
Kubota l2650
Jun 9, 2025
Northeast USA
I bought a l2650 did not come with any 3 point parts. has the arms that move with lever and top link bracket. Wondering if b series are similar, I’m pretty good at cutting and welding/can modify “universal” ones from tsc. At this point spending $2500 on individual parts is not in the budget. I am wondering if anyone knows if b series arms and links will fit? Or if somebody has a l2650 would you share some
Dimensions with me?
Dranul
Kubota l2650
Jun 9, 2025
Northeast USA
B series parts aren't correct. You need L series stuff- longer lift arms, longer/heavier stabilizers and side links, etc.
Contact Daryl Grammer- he's a member here, and he has a Kubota salvage yard in Alabama.
mossycreekoutdoors.comMossy Creek Outdoors - Largest Kubota B and BX Salvage Yard ...
im guessing the internet is only about the b series with replacement parts Anywhere I look. I’ll try to email Daryl, I’m in the north east so maybe he can either ship or share dimensions. I’m a steel fabricator that’s why I don’t mind making my own. Just need a reference to start with thank you.
3,573
2,170
There is a kit, L3961, that is made to fit the L size TLB's that don't come with the 3pt parts since they have a backhoe standard. It fits the smaller frame L35 as well as the larger L45/47, so it might fit your machine. I posted a picture with some measurements, you can search 'L3961' with my name and find the posts.
I think the current price is around $700. There have been reports of pretzelling the aftermarket arms. They're thin compared to the OEM parts.
hodge
Nov 19, 2010
2,959
535
Love, VA
He does ship. I have friends with an L2350- I can get photos and measurements of their 3 point (it's all original, other than telescoping stabilizers that I made for it), if needed.
MtnViewRanch
881
328
Lakeside Ca.
The top link and side links are the same as the L4200 up to the L4802.
I'm guessing that all of the 3pt hitch parts from these models will work for you.
rh74
LX4020, LA545, LX2980, RB1672, BB2560, PFL1242
Feb 17, 2024
62
70
NY
Just wondering if you talked to a dealer to see if the entire 3 point arm system is a whole good's kit. Buying it that way is extremely cheaper that buying individual parts.
D.jFarm78
L2250 FEL& L4610FEl, BH, Grapple, Mower, Gannon , blade, disc, plow, rototiller,
Mar 20, 2020
46
17
Young, Az USA
I bought a used tractor and it did not have the 3 point on it.
I found them at ASAP for $600.00 delivered. They included everything bolts pins and a top link.
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
Big difference in price from parts counter adding up the individual parts to get a complete hitch setup verses a kit from Wholegoods from a salesman. Found most parts persons don’t know how to order from Wholegoods.
if you are a good fabricator might consider making some pin type sway control bars instead of the OEM chains.
Modified the B26 3pt hitch immediately with Pat’s quick hitch, pin sway bars and geared side link adjuster. So much easier to hookup and adjust 3pt attachments for the past 9 years.
10,008
lift link adjustable you need 1:
Option you can use 2 adjustable links:
Lift link fixed you need 1::
Arms: Need 2
Sway bars need 2:
top link:
Top link pins either local Farm store, ebay, amazon
