New owner of L175...smokes terribly bad...
jollyrodger
Kubota L175
Jun 9, 2025
14
10
Sterling ks
Just bought a Kubota L175 (1975), and I think I made a mistake...this thing starts but sokes up the shop completely...it's absolutely terrible...any ideas?
I've adjusted the valves...but don't know much about injection pump or injectors enough to tear apart... i believe the pump has to be timed...and frankly just don't know enough...
lmichael
Kubota G2160
Apr 23, 2021
743
353
Rockford IL area
Depends on what type of smoke as well. It could be anything at this point. Excess fuel, bad oil burning, burning antifreeze. So you have to nail down what type of "smoke" you see
Hugo Habicht
G1900
Jun 24, 2024
833
1,150
Ireland
Good point. Black or white? I had assumed black.
jollyrodger
Kubota L175
Jun 9, 2025
14
10
Sterling ks
Thx guys, sorry should have said...it's not black...it's white/blue...smells like a lot of fuel...and doesn't clear up...could it be injectors not spraying and just dumping or is there an adjustment tofuel pump?
ruger1980
L4310 w/La682, L225
Oct 25, 2020
520
206
CNY
Well, I thought of blue as white(ish) as being burnt oil.
Blue can be excess oil bypassing the rings, or it could be unburnt fuel. White to grey can mean water/coolant or improper timing. Timing can also be a bit blue. Black is incomplete combustion
ruger1980
L4310 w/La682, L225
Oct 25, 2020
520
206
CNY
Is this with just a cold engine? They will often smoke quite a bit when cold. Try running it with a load to see if it clears up at all.
If it does not it could be injectors, timing or possibly poor compression. Maybe post a video of it cold and then warmed up.
whatsupdoc
L3302
Jul 9, 2024
116
124
I would do a compression test first, if it is low then there is no point diagnosing fuel issues.
Mruysch
M6950DT
Dec 12, 2021
26
12
Alberta
That's why I have an exhaust hood over my tractor exhaust in my shop. My tractor smokes horrendous amounts of blue when it is cold. Burns the eye's like crazy
jollyrodger
Kubota L175
Jun 9, 2025
14
10
Sterling ks
Here's the beast running...although I did let it run for probably 20 minutes and the smoke did lessen...IDK but it sounds like an exhaust valve isn't right...don't know if you guys can hear it...
Guess I can't show the video...can't find how to attach it...sorry.
2,315
You can post the video on your favorite YouTube or similar site and the put a link here.
But that amount of smoke isn’t right.
Start by getting a diesel engine compression check kit that will have an adapter for the glow plug ports. I would recommend you buy new glow plugs and get a deep thin walled socket that fits them and install the new ones after you have done the compression test.
I am assuming your tractor is fairly stock, the glow plugs are wired correctly through the indicator and you know how to use them correctly. But that probably won’t help with the smoke (after 20 minutes it should have been warm enough that the glow plugs would not help it start much).
You may want to replace the injectors and their seals (from the dealer or Oregon injection repair) to eliminate them as the problem if you want to spend that much money now without much troubleshooting done.
jollyrodger
Kubota L175
Jun 9, 2025
14
10
Sterling ks
The guy i bought it from said he put new glow plugs in and they do look new and they do work. I don't know if it's stock or ever been overhauled, but that much smoke i would say not...
Might be a winter overhaul project...and i wondered about trying injectors...
