23S starter burned up, found the wire to the solenoid is always hot
JSum
Kubota 23S, FEL, BH, MMM
May 29, 2025
12
Western PA
Looked for similar threads, but didn't find the exact information I was looking for.
I have a 2023 (I believe) new to me BX23S with just 33 hours on it. I have started and stopped it many times with no issue. yesterday after moving a trailer with it, I went to shut if off and it restarted twice. Even with the key out. I decided to move it to a different area so it wasn't blocking the garage. As I did, smoke started pouring out the side of the motor. I found that it was coming from the starter - now fried. I was able to buy a replacement starter, but decided to put the test light on the black/white spade wire and turn the key after reconnecting the battery. The test light was off and then turned on appropriately when I turned the key to start. The only problem is that the light stayed on indicating ongoing power to the wire even after I returned the key to the on position, turned it off and removed the key! I think that is why the starter burned up in the first place.
So, now my question is, how do I work this problem through? Is there a starter relay and if so where is it, or is it simply a faulty ignition switch? I have been searching and reading threads on here, searching the web, you tube and the WSM, but don't see a clear picture of where things are located and even what part to try to order. It raining out right now, but once it stops, I will go back out with fresh eyes and try to trace the wiring backwards from that point again and see if it makes more sense today....
JSum
May 29, 2025
12
Western PA
Update - had a quick break from rain so I was able to find the relays for the starter and headlights. I marked the starter relay and switched it with the headlight one and retested. I still have continuous power being delivered to the starter wire. Does that mean this is definitely a problem with the ignition itself? All the wires seem well protected and in the factory loom so I would think a short is less likely.
Blue2Orange
Apr 3, 2025
260
158
Bayview Township
Any local Kubota dealer? If so, shop and parts department should have an answer to your issues. There is a Limited Warranty Chart at the Kubota website. Maybe you have an issue covered by warranty.
3,301
You have a test lamp, so you can check the output of the ignition switch that feeds the starter relay.
If you go to the sticky thread at the top of this sub forum, you will find an electrical diagram in post #13 that is the same as the BX23S.
It sure sounds like it is an ignition switch issue.
Edit: the sticky is titled Electrical Diagrams or something along those lines...
JSum
May 29, 2025
12
Western PA
Several dealers, but I am not the original buyer. Talked to several parts people and they have helped out as much as possible.
JSum
May 29, 2025
12
Western PA
I had the same thought. Just got back from the dealer and put a new ignition switch in.
Same problem...... The wire going to the paddle connection that is on the starter is energized all the time. Its as if it is hot wired directly to the battery! I don't have a clue how that can be happening! Any malfunctioning safety sensors should PREVENT energy from going to that wire.
9,725
The warranty follows the tractor not the owner, the warranty transferred to you when you bought it.
JSum
May 29, 2025
12
Western PA
UPDATE #2
I removed the starter relay completely and tested the wire that attaches to the starter solenoid and it STILL has power! Shouldn't it be dead? Its reading 12.4 volts. I can't figure out how this is still hot! The wiring diagrams in the WSM from Kubota books and from the electric subgroup #13 are blurry no matter how I try to zoom in on them and they quickly confuse me anyhow.
Starting to think I need to install the starter and just disconnect the wire once it fires up and load it on the trailer and haul it to the dealer.
I wonder if any of this would be covered under the warranty if it is even still under warranty. I'm the second owner and was told it was a 2023 machine. I imagine a dealer could run the serial number to see when it was put into service.
Anyone have some good insight to where I can look or what to try next?
3,301
First, look at the PDF file of the wiring diagram that I referenced above. That way you can zoom in and it is clear!
Second, if you replaced the ignition switch with a new one, then chances are that the problem was not with the ignition switch. Perhaps you have a short in your wiring somewhere.
Connect your test light to the voltage point you question, then start moving wiring harnesses and stuff around and see if the light goes on and off. This would probably indicate that it’s a wiring issue.
Just a couple thoughts…
I would think the dealer could tell you whether the warranty is active or not if you gave them the serial number of the tractor. It might be worthwhile asking them before you take the tractor there and end up paying big bucks for something you could probably figure out yourself eventually.
Of course if money is not an issue, take it to the dealer, and relax!
6,039
Stuck/shorted starter relay?
You can disconnect the wire onvthe starter solenoid and start the tractor by jumpering the battery post to the solenoid terminal.
JSum
May 29, 2025
12
Western PA
I haven't installed the new starter yet because the i discovered the wire to the starter solenoid is hot at all times. I'm trying to trouble shoot that now. Guess i will tear into the wiring harnesses today.
6,039
I would remove the starter relay and check that wire again.
JSum
May 29, 2025
12
Western PA
Good idea. If money wasn't an issue, I would have a brand new machine not a used one! I wanted to see if I was missing anything obvious before I started tearing apart all the nice factory wiring harnesses. That is a really good idea to connect the test light and then jiggle the wires and see if it flickers or goes off. May help me localize an area. I'll do that today and report back what I come up with. Thank you.
6,039
The socket where the starter relay would plug in? How could I test that?
Not knowing the physical layout I am guessing. I assume this is a four pin relay. Remove the relay, disconnect the battery feed and see if the solenoid pin loses power.
Dustball
2016 B2650HSDC
Sep 15, 2023
460
320
Hudson, WI
Here's the wiring diagram pertaining to the starter on the BX23S. It's very straightforward so there isn't too much to check.
Battery > 50 amp slow blow fuse > ignition switch > PTO safety switch > HST safety switch > starter relay coil
Battery > 50 amp slow blow fuse > starter relay common terminal > starter relay N.O. terminal > starter solenoid
Pull the starter relay. Check for continuity between the red wire and the black/white wire at the starter relay socket. If you have continuity between those two wires, those two wires are shorted together somewhere along the path.
If there's no continuity between those two, next check for 12 volts between the black wire and the black/yellow wire at the relay socket. The 12 volts should be switched on/off with the ignition switch and with the opening of either the HST or PTO safety switches. If there's always 12 volts coming from the ignition switch but turns off with opening either safety switch, it's the ignition switch that's the issue. If there's 12 volts always with either safety switch open, the 12 volts is coming from somewhere else between the HST switch and the starter relay socket.
JSum
May 29, 2025
12
Western PA
It's fixed! Maybe I made a rookie mistake.... I went back and looked at the owners manual and the WSM and I don't see anywhere a picture showing where the relays are. I mistakenly thought they were on the left side of the tractor behind the housing that conceals the battery. It says STARTER and RELAY on it. The ACTUAL relay (which was the problem and fused itself closed causing constant power to the ignition wire.) is under the dash/ instrument cluster. I found this as I took Henro's advice and traced the wire backwards. I ended up removing all the electrical tape and wire loom back to the battery and then up to the instrument panel.
Maybe what I learned will help someone else next time. Below are pictures I took as I worked. First ones show the small tan Denso Relays that I thought were the only ones. The last ones show the typical automotive 5 blade relay that was the problem. I was able to pick up a universal 30amp relay at the local auto parts store and didn't have to wait till Monday to get from my Kubota dealer.
Thanks everyone that offered me help and encouraged me to keep at it to find the problem myself!
Reactions: 7 users
