Need help freewheeling my PTO on my Kubota L3902
Bob the Farmer
Kubota L3902
Jun 5, 2025
I got the rototiller all hooked up, but the splines don’t want to match up, and I don’t know how to freewheel the PTO so I can move it to the correct position. If anyone can help, that would be great.
Moose7060
Oct 14, 2023
827
2,243
bc
Just to make sure, are you pulling back on the lock collar while trying to fit the pto to the tractor?
2,150
There are tools to turn the tractor PTO shaft like this
You may be able to pick the tiller off the ground and rotate the driven shaft but that is dangerous unless you put some blocks under the sides and set the tiller down on those.
Bob the Farmer
Kubota L3902
Jun 5, 2025
Will try that thanks 👍
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
41
30
Lakes Region, NH
Do you have the PTO shift lever out of gear? If your tractor has the push button electronic PTO on/off button, your PTO shaft remains somewhat engaged as long as the PTO shift lever is engaged. I found with my LX4020 (that has the electronic PTO on/off button) that I must have the PTO lever in the neutral position in order to manually turn the PTO shaft by hand.
trikepilot
B2620HSD w/ LA364 & BH65 48SQ Bush Hog LandPride FDR1660 LandPride RB1560 Woods
Jul 18, 2020
115
155
Hardy, VA
i just put the tractor in "N" and spin the splined PTO stub out the back of the tractor with my gloved hand to get it lined up with my finish mower or bush hog. Turning the PTO shaft on my implement is ALOT more effort.
Moose7060
Oct 14, 2023
827
2,243
bc
Yes, I am pulling back on the collar.
That confirms the collar isn't seized up. Other than the suggestions above, I would start the pto momentarily and shut it off and with the tractor turned off try again and see if it is aligned better for you. Ensure nothing is close to the tractor pto shaft of course. Good luck.
3,281
1,901
A lot, maybe all, of the newer tractors have a brake on the PTO shaft that engages when the PTO is in neutral. This makes hooking up the shaft a pain, as you've discovered. As someone mentioned, often it's easier to lift the implement and turn it.
To prevent premature wear to the brake, reduce your PTO speed before disengaging it whenever you can, especially with a high inertial load such as a brush cutter.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,632
1,898
Near Lancaster, PA, USA
When engaging the PTO for my mower, I reduce engine speed to idle, depress clutch, flip PTO "switch" ON and ease the clutch out.
Orange man
Kubota L2502 LA526 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
256
166
WNY
I have not found a way to be able to spin the pto shaft on my L2502, the L3902 uses the same pto system as the L2502.
whatsupdoc
L3302
Jul 9, 2024
108
119
I have a L3302 and I will spin the implement by using a steel bar in the U-joint to line up the splines. The PTO shaft cannot be rotated by hand.
Smokeydog
Jun 2, 2020
757
728
knoxville, Tennessee
No love for the newer braked pto.
After I installed Pat’s quick hitch, I also installed PTO overrunning clutch. Makes drive line connections easier. Also didn’t need to brake high inertia loads like rotary cutter or tree cutter and cause undo wear on tractor internals.
Survivor
L2501
Jun 8, 2025
46
41
I am SO GLAD that I bought a 2501 while they were still available before they mucked it up with the 2502!
A few supposed "improvements" with some electric switches and the L2502 is no longer a simple "old school" basic tractor. :mad:
kbates
B6200 with loader - B7500 - LX3310 with loader
Jan 2, 2012
10
Regina, Sk
kbates
Jan 2, 2012
10
Regina, Sk
When I encounter that problem, I put the mid PTO in gear and then I can turn the rear PTO by hand. Works on my B7500 and LX3310. Hope this helps.
