L2900 Won’t turn over.
Acrob
L2900
Jun 9, 2023
NJ
Hi, 94 l2900 will try to start but won’t turn over. Battery tested good. And put a new starter in and still same issue. Can anyone give me some other ideas. Diagnosing issues is not a strength of mine haha.
Thanks
3,058
Lets get some more info
Is this a shuttle shift? IF SO - the neutral safety switch may be the problem, there is a switch in the shuttle shift level
How do you know the battery tested good? Load test?
Does it click or make any noises at all when the key is turned?
Acrob
L2900
Jun 9, 2023
NJ
Yes shuttle shift. Has 12v coming from battery and it’s only a year old. It does click when trying to start. Just won’t turn over. I don’t think I would get anything if the safety switch was bad?
7,272
12V @ 10mA will deflect a voltmeter but wont crank the starter. To fire up the starter you need several hundred amps.
These types of problems tend to fall into two categories.
  1. One or more bad connections between battery and starter.
  2. Bad/weak battery
I usually start diagnosis by jumpering the battery and solenoid terminals on the starter. If it cranks the battery and starter are good.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,293
183
Coyote Flats,Texas
I suggest to check/clean/tighten all 4 battery cable connections paying special attention to ground cable to frame connection. I also suggest to load test your tractors battery
Acrob
L2900
Jun 9, 2023
NJ
Connections look good. I had that issue last year. Am I correct in thinking that if it was an issue between the starter and ignition I wouldn’t get any clicking or it trying to turn over?
7,272
So it "tries to turn over".
Does this mean the starter does engsge and partially roll the engine?
11,086
Do you have lights?
Dash / Instrument indications?
A bad / active safety switch will keep it from cranking.
The noise your hearing could be the stop solenoid activating.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,293
183
Coyote Flats,Texas
Appearance of a battery cable connection can look good similar to a good appearing woman but be bad just the same!!
11,086
Make sure the stop cable is not engaged:
Bottom right under the dash.
If it's not engaged, then it's more likely a fuel delivery issue than anything else.
Any smoke out of exhaust when cranking?
Acrob
L2900
Jun 9, 2023
NJ
Thanks all. It ended up being a bad battery. Voltage was good but bad load. Interstate under a year old!
7,659
The shop I use that use to sell Interstate batteries quit handling them because of too many returns and poor customer service from the supplier. That was a couple of years ago.
I have better luck with Walmart batteries and no questions if/when returned.
