B6100 front loader hydraulic pump
dave86
B6100
Oct 10, 2019
14
WOODLAND
Spool valves and gear pumps are not generally rebuildable. When they die you replace them.
Your loader valve is two handle operation. You can replacce it with the same thing for $189:
Or for $60 more you can upgrade it to a joystick. I think thats a no brainer:
I have put something close to a hundred of these pumps on various tractors and they are the first place I look. This one will give you 7 GPM @ 2000 RPM and should bolt right up. You can go bigger or smaller for the same price. You will also probably need to replace the pump half of the chain coupler with one that matches the 5/8" shaft on these pumps - another $15.
One last thought. I dont think that loader had a hydraulic filter and if not I would definitly add one.
IT does not have a filter. What filter would you recommend? On which line should it be mounted?
6,257
well the manual does tell how to assemble it, gives parts list and sizes, and how it works..
that information is 'neat' to me and could be important to owners of that loader.
ANY info from the OEM is nice to have, as you can compare what you have to what WAS there, from the factory. Over the past 4 decades,someone could have replaced something,which may affect how it performs.
Swede1962
B6100D 4x4
May 3, 2025
78
44
Overland Park, Kansas
I have a B6100D and a B219 front loader. I have a pump with a shaft sticking out one side and a chain sprocket on the end of the shaft, nothing more. Where does one find the part that rides on the splined shaft and drives the pump? Or is this a trip to my favorite machinist shop to see if he is really as good as he thinks he is?
7,034
That shaft is rare as unicorns. Your machinist better be knowledgeable and well equipped - 25mm internal involute spline, pressure angle unknown. He might be better off making something from scratch for that end.
Swede1962
B6100D 4x4
May 3, 2025
78
44
He’s knowledgeable and very capable. My first thought was to open up the front bracket area to better accommodate a pump setup and then circle back around with a new enclosure/protection designed into the front of the frame area under the radiator. It seems working room is minimal in that area creating in part this will friendly setup to drive the pump. Your thoughts?
Swede1962
B6100D 4x4
May 3, 2025
78
44
That spline shaft bolts into the end of the crank? Is that right?
2,983
@TheOldHokie and @Swede1962
I thought I had posted this link to a similar thread the other day. The thread covers how one person found a part and modified it to work as the front PTO shaft and @TheOldHokie posted a drawing of a simple machined shaft to fit over the splined shaft.
Swede1962
B6100D 4x4
May 3, 2025
78
44
Is this your drawing?
Yup. It’s not the correct reference to what we’re talking about. I just figured that out.
My question is why can’t I put a splined gear that accepts the chain drive to match the chain drive gear I have attached to the old pump I got with the loader? I can either buy a gear ready to install on n the shop lined crank shaft or have one made to mate up with what I have in hand. I think I can solve my problem this time way.
Swede1962
B6100D 4x4
May 3, 2025
78
44
Where did you source the gear?
Swede1962
B6100D 4x4
May 3, 2025
78
44
I’m putting this in my watch list so I can let my machinist read it and see what needs to be done. This is out of my wheelhouse too far. Thx a bunch for the info. 👍
2,983
I am not sure what “gear” you are after unless it is the chain coupling half you are calling a gear.
As I understand the arrangement, there is already a splined shaft on the engine, then a shaft was added to extend out the front of the tractor. On the end of that shaft and on the pump shaft two matching coupling halves were mounted. The pump was face mounted and then a double row chain was installed on the coupling and connected together.
Those couplings are available in many places (McMaster Carr).
7,034
I suspect your gear is actually a chain sprocket which is one half of a chain coupler. The other half of the coupler goes on the end of the tractor side shaft and a double row chain is wrapped around them to join the two shafts. An inexpensive standard part.
The hub in the parts diagram I posted fits over the nut for the crankshaft pulley and bolts to the face of the pulley.
My suggestion is have your machinist make a custom hub with a standard keyed bore for the crankshaft. From there out you can use off the shelf shafting to connect the hub to your pump. Easy for the machinist and you.
