B2601 with front mount snowblower
oakhilltop
JD 2305
Jun 1, 2025
nh
I am considering the B2601 with a loader and front mount snowblower. The salesman spec'd the SB1064 snowblower. I currently own a JD 2305 with a 47" snowblower and I find that is big enough. I think that a BX2822A snowblower may fit on the B2601. That blower is 55" which I think would work well for me. The B2601 is spec'd at 49" wide and I will probably go for the wheel spacers. That should still be less than the 55" of the snowblower.
Will the BX2822A mount on the B2601? The main reason for wanting the smaller blower is for fitting into somewhat tight space in the garage.
Also, any feedback on what it is like to mount the snowblowers after taking the loader off would be appreciated.
oakhilltop
JD 2305
Jun 1, 2025
nh
The SB1064 is a rear mount, and I want a front mount. Something like the bx2816, but that is 50". If I put wheel spacers on the B2601, then that blower will be narrower than the tires. I'll discuss the options with the dealer, if I decide to go with the B2601
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
100
Ottawa, ontario
I'm using a BX2755HD 55" front mounted on my B2601. Perfect size and always does the job. I find with the heavy wet snow a larger blower would plug up.
oakhilltop
JD 2305
Jun 1, 2025
nh
Thanks, that's the info that I was looking for. I think the 55" would be best for me also
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
I have used both front and rear blowers. I much prefer the front mount.
WI_Hedgehog
Apr 24, 2024
770
1,019
Milwaukee, Wisconsin, U.S.A.
(snipped for brevity) Considering a B2601 with 55" BX2822A front mount snowblower. The B2601 ~49" wide and I'm thinking of wheel spacers. Will the BX2822A fit, and what's it is like to mount a snowblower after taking the loader off?
I have a smaller tractor, BX2370, so my experience relates but isn't exact.
A rear-mount blower is great for some people. However, the older a person gets, the more difficult it becomes to do multiple things at once, like twist around and operate pedals and steering while not blowing ranch lawn lamps out. Now clearly I'm not saying old people can't do things, just that wherever your skill and mental set is now, it will become "more difficult the older one gets." Plus Older->Colder, so working against more clothing is more challenging, which again is doable, I'm just mentioning it because others tend to overlook it. Despite the additional expense, from my reading most members here seem to prefer a front-mount blower. @Speed25 helped me with not-quite-new snow equipment and made the situation affordable (plus he has mad crate building skills).
In my case front-mount has a mid-PTO drive shaft that goes to the front lift that once mounted stays on the tractor for the season, and while not too complex it's a bit of a challenge to get on, but I'm old so that's likely factoring in. Switching between a plow and snowplow is easy: pull up, push in, throw a locking leaver (and pin it), connect 3rd function hydraulic lines, and I'm off. Sometimes the front driveshaft on the blower doesn't fully line up perfectly, but over-all it's actually easier than messing with a 3-point shaft in the cold.
For me, it's either the loader or the front lift, the loader stand gets caught on the lift tongue otherwise (and that sucked--don't do what I did by trying to make both work at the same time without more carefully checking clearances).
I'm running a 50" blower, with deep (1-1/4 foot plus), wet, heavy snow that means creeping along slowly (I have a video on that), so you should be about the same with a 55".
I have two sets of 2" wheel spacers so can get out to 4" per side, 8" wider total, and in the woods that's great. On pavement there are several reasons why spacers aren't great. First it makes turning much, much harder, especially with a blower out front (the tractor has more of a tendency to want to go straight). Second, if you're in 4WD it screws up the turning radius even more. Third, it's worse with rear chains, and fourth: worse yet with front chains. And, when turning one rear wheel cuts the corner short, so while blowing turning works best with a long, sweeping turn, narrow stance, and blower that's wider than the wheel track. I have a weight box out back though it's narrow enough that's not an issue.
Keep things clean and lubed, with fresh non-gummy grease and it all goes together pretty well.
The only thing I'd really change is to put a blade out back so I can blow and scrape at the same time.
Hope this helps, it's not exactly what you're looking to do and I'm not sure what fits a B, but with a fairly universal lift up front (BX2751, seem my Profile->About section for details) I can plug in several different things easily.
oakhilltop
JD 2305
Jun 1, 2025
nh
I am not considering a rear blower. Thanks for that info about the spacers. I'm not sure what to do about those now. I was thinking 2" on each side, which should help in the woods. But I don't want to reduce maneuverability elsewhere. I'd be interested in hearing experiences of others with spacers.
One thing that keeps coming up with tractor snowblowers is chute deflection control. Many manufacturers don't offer it at all. I have it on my JD setup, and it is a simple cable from the chute deflector to a bracket near the seat. There's a handle that I simply push or pull. Nothing more is needed ..... for me. I got a quote on a Kubota electric deflector of $900! Grrr!
oakhilltop
JD 2305
Jun 1, 2025
nh
I'm also considering putting a blade on the back for the days with a few inches of wet slushy snow. I could push most of it off while driving backwards, staying away from the edges.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
I have used my blowers as blades, in cases of slush. You just need to engage the blower after you are done to clean out the left over slush.
WI_Hedgehog
Apr 24, 2024
770
1,019
(snipped) I'm not sure what to do about 2" spacers which should help in the woods, but I don't want to reduce maneuverability elsewhere.
I don't have chute deflection and just leave it pointed up, it throws the maximum distance. Rotation would be nice, I'll have to work on that. There are several threads on D-I-Y chute controls.
What I do on a BX makes me hesitant to buy a B: For the hilly, often slippery woods I rattle-gun turf tires off, add two sets of rear spacers, and put M4 wheels front and back. For mowing I rattle all that off and put the turf wheels back on so as to not tear up turf. I don't load my tires so they swap "easily," but if selling the BX to buy a B...not sure I want to keep doing that plus a mower deck on a B. Like you I have limited storage, so I'd need to put up another building for another tractor, and that seems "not a good return on investment."
thebicman
Feb 2, 2017
337
100
Ottawa, ontario
My blower didn't have a deflector either. Was stupid expensive through Kubota. I installed a linear actuator with a switch on the dash. Never thought I would use it and was I wrong. When the wind is blowing in your face I deflect it as low as possible to keep the snow out of my face. Probably $150.00 total in parts.
oakhilltop
JD 2305
Jun 1, 2025
nh
I can't understand why deflectors are not standard. Most walk behind blowers have something that the operator can use to change the deflection. For me, it doesn't have to be a push button electric or hydraulic. A low cost cable with a handle is fine. I live on a hill, while the pavement is level left to right, the terrain also slopes left to right. So, I want to blow as much snow as possible to the left while going down, and to the right going up so that there will be less running across the pavement when it melts. But, when I get to the top, I get out of the trees and the wind can be whipping. I want the chute down more. Not to mention that the wind may be, usually is, blowing towards the house. There's no sense in trying to fight the wind, just need to go with it. But I don't want stuff flying at the house and windows, so I deflect it down more.
Do you have a link to that actuator that you put on the Kubota?
