D902 pistons for bored block
New31127
Bx2350
Apr 24, 2025
20
North carolina
When I look at pistons it says serial numbers for reference but I’m assuming it’s different pistons where do I find the serial number for the engine I need to know what size it needs to be bored too idk if the pistons or 20 or 25 over
New31127
Bx2350
Apr 24, 2025
20
North carolina
In other words from what I see you have to order the pistons according to your serial number any help would be much appreciated
5,504
2,211
usually on the block under the injection pump. There is a machined surface, under and to the right of the pump, that has the engine number stamped into it. Often it's not easy to find, so look real closely. It should say something like "D902E-28873" or something. Everything after the dash is the serial number.
New31127
Bx2350
Apr 24, 2025
20
North carolina
Would be my luck block is already at the machine shop anyone’s eyes good enough to see the rest of the numbers
9,247
I have really good software and a 32" computer monitor, and I can't make it out.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,760
2,123
Near Lancaster, PA, USA
What does the serial number tell you that size does not? Are there different pistons of the same size?
I don't know, but here's from the OP:
5,655
The OPs comment was confusing because its associating oversize with serial number. Messicks part page is evrn more confusing.
The Kubota site is much clearer. There are three serial number breaks for the piston. Within each serial number break you have options for STD, .20, and .25 oversize pistons.
So the OP needs to know the block serial number AND what oversize if any for the block.
New31127
Bx2350
Apr 24, 2025
20
North carolina
Yes messicks is where I got confused so what your saying doesn’t matter the serial number they are all either .20 or .25 over that’s what the machine shop wanted to know so if it need boring they knew what size and the serial numbers and pistons confused me
5,655
I believe that to be the case.
One thing I have recently learned is Messick's pages are not always the same as Kubota's and sometimes Messick's is just plain wrong.
Dzn
New31127
Bx2350
Apr 24, 2025
20
North carolina
Dzn
Dzn
Mind posting the link for kubota?
5,655
