B2150 hst front rims replacement
Derekm361
Kubota b2150
May 30, 2025
Need help. I have a b2150hst and I need to buy new FRONT wheels and tires. I want a wider rim also so I can run wider tires so I don't make ruts with the pizza cutters that are on there when I go into my yard. Does anyone have a link of some wide rims that will fit my kubota ?
11,202
23x8.50x12 tires
You will also have to switch out the rear tires and rims also to keep the ratio right.
13.6x16
LHolschuh
B2150HST FEL backhoe tiller stump grinder B2920 HST FEL MMM grass catcher front
Sep 1, 2025
Huron , Ohio
32711-57420
23x8.50x12 tires
13.6x16
Do you know what the front tire size is if the rear tires are 12.4-16 R4 ?
Any suggestions as to where to find them ?
LHolschuh
Sep 1, 2025
Huron , Ohio
12.4 - 16
Match is
6-12
aren’t the diameters on them 23” ?
That’s the same as 23x8.50-12 R4 tires ?
I have the 23x8.50-12 ‘s on my B2150hst and one of the rims is a 2 pc. 7-12 and the other is a regular one pc. The 2 piece is cracked on both sides and I haven’t been able to find one with the correct bolt pattern and center hole.
I am really hoping that the R-4 tires are the right size. The rear’s are new Goodyears on new Kubota rims 12.6-16.
any info on a good supplier for old stuff would be greatly appreciated. Thanks
11,202
You are swapping all the numbers around
If you have R1 8.3-24 or 12.4-16 rears, you need R1 6-12 fronts.
If you have R3 or R4 13.6-16 rears, you need R3 or R4 23x 8.5-12 fronts
If you have R4 12.4-16 rears, then I don't know what size front you need because that's not a valid combination.
23 x 8.5 - 12 will more than likely be much too large.
Do you already have R4's on it?
As R4's will not mount on the 16" rim from an R1, they are too narrow of rims.
If you do already have R4's on it you will need to find out the RC of that time to determine what the RC of new front tires needs to be.
LHolschuh
Sep 1, 2025
Huron , Ohio
The tractor had the original turf tires on the rear 13.6-16 and then the fronts got changed to R4 from turf.
the rears that I have now are 12.4-16 that I got from a new B series tractor.
the rears fit perfectly but the fronts have a different bolt pattern and center hole compared to my 1995 B 2150.
I bought the set of 4 tires from a new tractor.
The fronts were 23x8.50-14NHS. I have 1 good rim that was replaced years ago that was stamped D.I.D. Japan 12x7JA . The other is the split rim from the original turf tires.
Out Kubota dealer said the rim I am looking for is $600+ .
looking for options or used one.
I don’t think the split rims were intended for use with 23x8.50-12NHS tires.
way to much side pressure. They will crack at the lug stud.
11,202
Your not understanding...
You CAN NOT run 12.4-16 rears with 23x8.50-12 fronts, you will break parts of the 4wd.
You also should have never had 23x8.50-14 on it, as you stated you have.
This is all the tractors that took that original 12" rim.
LHolschuh
Sep 1, 2025
Huron , Ohio
I found a lead lag calculator on the titan site and found that the rear tires (12.4-16 R4 Goodyears ) and the front ( 23x8.50-12 titan trac loader II ) is right at the high limit of safe operation.
given that the rear tires are new and the fronts are at 50% life , I think I will chance it.
this tractor had been neglected and abused by prior operators because they don’t have to pay to fix it.
I just had this tractor serviced recently and they did do the front axle and hub inspection and found no problems so far.
I think they had it in 4wd all the time just because they didn’t know how to disengage it.
just knowing the stuff this has gone through and it runs and operates the way it does makes me not want to replace it but if I do replace it , it will definitely be a Kubota. Hands down.
now that I know what diameter tire to get I just need to find a 12” x 7” rim with the right bolt hole and center hole.
Thanks for your time.
sorry about the confusion with what I was looking for.
jshaw
B2150
Jun 13, 2026
ARkansas
I have the exact same issue. Did you ever find a replacement "Kubota D.I.D. JAPAN 12X7JA 6 lug 23x8.50-12 rim
Ravin26
B2150H 4x4
Sep 21, 2026
Traverse City
Do you still have your front 24x8.50-12?
