Good running to bad in an instant
Zorm
2003 BX2200, belly mower and front loader
Apr 28, 2024
20
Florida
Folks, got a 2003 BX2200. Bought the tractor used about 2 years ago. Has belly mower and LA211 front loader. I was working with it yesterday doing loader work, filling in and leveling two septic tanks. As I was smoothing out my last run for the day, I was backing up and all of a sudden, the engine started shaking violently and I had no power, then it died. I tried to restart but when it finally did, it’s was running like it was before it died. I thought maybe I ran out of diesel, so filled the tank. Tried to start again, took a few turns, then started and ran like crap again, I thought maybe it needed time but it eventually died. Moving the throttle does nothing.
Need some help here please. Bad injector?, injector pump?, crappy fuel? stopped up filter?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
908
875
E.
My initial guess is crappy fuel.
Would be my first and easy to check and clean.
Alge grows in the fuel between the layer of water / fuel and when alge colony gets large enough it falls out of suspension and can start clogging stuff down stream from the tank.
I would start with a clean from head to tail replacing / cleaning filters, etc.
I never owned exact model so not sure what you have for filters and separators but what you describe seems to fall under category that we call around here the green snot of death.
Dustyx2
BX22, M7060, Landpride RC-2512, Woodmax SB84
Feb 19, 2021
238
85
NE Wyoming
Owner of a BX22 so the TLB version of your BX2200. First thing, when you turn the switch on do you hear the fuel pump clicking? If you don't, check the 15 amp fuse behind the battery cowl. If the fuel pump in clicking, I'd next check/ replace the fuel filters. There are two of them. one under the tractor pre fuel pump, and the other is next to the loader tower if I remember correctly. While you have the line off the fuel filter, make sure you have good flow and maybe drain some in a clear jar so you can check for water, algae or other contaminants. I have 1200 hours on mine and still on the original fuel pump.
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
210
339
Grayling, MI.
If it turns out to be crappy fuel it probably is water in the fuel. Don't know if your machine has a water separator or not, but that would definitely help in the future
Dustyx2
Feb 19, 2021
238
85
NE Wyoming
No separator unless someone added one. I have a bulk tank with a separator so no water issues in my
equipment.
Hoserman
Aug 1, 2022
210
339
Grayling, MI.
That's cool. Our 980 Cats at work had inline water and fuel filters. I was amazed at the amount of condensate water that was in the separator.
BX'r
BX2370
Jun 13, 2020
114
24
Sault Ste. Marie, Ontario, Canada
When my bx did this it was a blockage at the tank outlet.
The fuel is drained from the filter and can't refill quick enough causing fuel starvation.
I discovered this by pulling the fuel line at the filter to check the flow and discovered the blockage.
Blew compressed air back towards the tank and cleared it.
I suspect it was ice forming from water in the bottom of the tank.
Changed my fuel additive and haven't had a problem since.
Pull the filter and check the flow of fuel.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
175
183
Fuel pump... I'm on my 3rd...only 400hrs. Ridiculous.
My JD 1025R was clogging the inline fuel filter every 20 hrs. No matter where I bought fuel, every 20hrs I would have to change the filter. What a PIA.
After the 3rd time (62 hrs) I took it down to the Kubota dealer and traded it in on a B2601.
Two years later, not one problem.
No more green for me.
Zorm
Apr 28, 2024
20
Florida
Thanks for all the good info gents. Actually had a bad fuel pump, replaced it and since I was there, replaced the filter between the tank and pump. After that, the filter was not really filling up as quickly as I thought it should.
So traced the lines back to a plastic housing on the right inside frame rail with 4 lines on it. 1)A vent to the top of the right side rear wheel well, 2) the line from the bottom of the fuel tank, 3)the return line from the injector pump and 4)the line going to the pre-pump filter and fuel pump. I traced the line back to the fuel tank, removed it and hardly anything came out. Stuck a zip tie in and had a good rush come out, found a floaty. Drained the tank with a hand pump, well as much as I could. I went back to the fuel outlet and poked in it a few times, reconnected the fuel line, added fuel, pulled the fuel line for a sec and had a good flow come out. So reconnected that line again, saw the filter fill up.
Jumped up to the injectors, cracked all three and let the pump run without turning over, didn't really see anything, so I cranked it over and did have fuel eventually come up to #1 (front most) injector, nothing at 2 and 3. Closed #1, left 2 and 3 cracked. Cranked her over again, eventually, got fuel at #2, tightened it up. Cranked her up again, nothing at #3. Closed it and opened the vent bolt on the incoming line to the injector pump. Let the pump run and got fuel there, closed it and cracked open #3 injector again. Cranked it over again and eventually got fuel at #3. So closed all and tried to light her off again... nothing.
Talked with an old friend and he was saying to make sure there is fuel coming back through the return line to the tank, or in my case, that plastic housing with the 4 lines. Instead of crawling under the tractor again, I removed it from up by the injector #1 (towards the front of the tractor).
Now at first, I let the pump run and had a small drizzle of fuel come out of the injector side, once I cranked her over, did not really get anything come out. Reconnected that line and found a small rubber "T" line coming off of #3 injector. I tried to maybe pull one of the lines in that T off the injection pump but in doing so, made a small slice in the hose and it did not come off. I turned on the pump again and had bubbles coming out of that little slice. So I cranked her over again, this time she sputtered, ran, real rough at first shaking real bad, then just about settled out to normal running for a few seconds, then went back to running real rough. I turned her off, let it site a few min, cranked her back up again, and again, she ran real rough, like shaking real bad, the she smoothed out to normal running for a few min, and then right back to running real rough.
So, do I still have air someplace, like a bubble circulating? do I have a bad injection pump? could I have crap in the tank killing the flow intermittently? Thoughts please
2,588
Sounds like you still have a fuel restriction. Runs OK at first (has plenty of fuel) then runs rough(lack of fuel). Let it sit and fuel (slowly) flows through the restriction and builds up a reserve. Then you start tractor and the cycle begins again.
You may have a biological growth in the fuel tank or you may have physical blockages of bugs or plant materials or man made materials in the tank or the fuel lines. Did you actually see what you termed “a floaty”? What did it look like?
I recommend that you search this site for “fuel blockage” to see if that sounds like your tractor and read how they were resolved. You could remove fuel lines to see if you get a consistent good flow or if it slows down significantly. The lift pump may not be working properly.
Good luck but I think you are needing a good fuel system cleaning!
5,993
I suggest you pull the tank off and properly clean it. Yes, I know PITA, BTDT but it's the ONLY way to CLEAN the tank. You've got a 20 year old machine,so tank could have LOT of 'floaties' and 'wall hangers'.....
When I did my BX3S, years ago, used garden hose with strong spray to get into every nook and cranny, did it 3 times, drained, blew with compressed air, etc. Final 'flush', I used winter WW fluid, then blew dry, then sat in sun for 3-4 hours. Yeah paranoid I suppose BUT have put 1000+ hrs on it and ZERO fuel issues.
Zorm
Apr 28, 2024
20
Florida
Thanks folks, looks like I'm pulling the tank this weekend. As far as additives, what are you guys using? thanks
Grandad4
Apr 5, 2016
407
159
Greensboro, NC
You said you replaced the filter. This tractor has TWO fuel filters. One that is easy to find and another hiding above the rear axle. If you don't replace both of them, you'll have a fuel starvation problem sooner or later. Other issues can also develop but the double filters are regular maintenance items.
Zorm
Apr 28, 2024
20
Florida
Grandda4, I replaced the filter before the fuel pump under the running board, since I'm screwing with everything, may as well change the filter before the injector pump.
This past Saturday, I did remove the little bit of fuel from the tank. Vice taking everything off to remove the tank, I thought I could get most of everything with a small vacuum. Once I got the fuel out I stuck in the vacuum hose, hopefully directing it to the small sump area where the fuel line leaves. It sucked up a bunch more fuel but also some black stuff. I dumped that out, then went back and vacuumed out more of the black stuff out of that sump. I went back a third time and did not get a whole lot. So I dumped some fuel back in, and tried to start. She did light off, and ran real rough, shaking badly, never getting to that smooth normal run like the other day.
I cracked the injectors and had fluid or at least air and fluid. Tightened them back down and then she would not fire off at all. I tool the return line off the injectors and had nothing coming out, which I'm kind of confused, shouldn't I see some fuel coming out?
2,588
You probably have a clogged tank outlet now. You can try blowing a low pressure air stream back towards the fuel tank through the fuel lines but remove the cap from the tank and cover it with a rag.
You may also just need to do the bleeding process to get air out of the fuel lines and injectors. That should be covered in the operation manual and be fairly easy (I think).
farmerNick
Bx2380
May 30, 2025
SEMO
Welp, the 3rd lift pump is now doing what the 1st two did...stops working after about 5-10 mins of work. Work = just driving.
1st Lift pump quit intermittently.
I have removed the in line filters. I installed a larger inline, water separator type bulb filter. Installed 2nd new lift pump. Took about 30mins of work before it happened again... SO, No changes. (I'll put another in-line before the lift pump, after I solve this issue.)
I installed a 5" cleanout/access in the top center of the tank. Siphoned empty. Dried, and vacuumed inside the tank. Installed a screen around fuel port. Also added strainer to fuel fill opening. Tank is clean. Installed 3rd new lif pump. Worked for about 20 mins. So, Still no change.
What is killing these lift pumps? Or is it that they are Chinese crap?
Grandad4
Apr 5, 2016
407
159
Greensboro, NC
With apologies, I probably wasn't clear. On a BX the fuel from the tank must pass through 2 INLINE fuel filters on the way to the engine. It's often the first filter, which is beneath the tank and hard to see, that gets clogged up. Many owners, unaware there are 2 filters, replace the second, more easily seen one further toward the engine and still have fuel delivery issues because they missed that other filter.
Proper maintenance involves replacing both filters. It sounded like you replaced a filter, but didn't say which one and I was just giving you a heads up.
Best of luck sorting out the issue.
2,588
I think you are getting junk pumps if you are buying them from the internet. I would suggest getting an OEM pump or one from a automotive parts store if you are having problems through your current supply chain.
You might need to replace the fuel hoses between the tank and pump(s) to insure that you have sufficient fuel flow???
Zorm
Apr 28, 2024
20
Florida
Alright folks, finally got my "little mule" running well this past Saturday. I was contemplating taking all the rear sheet metal off and remove the tank, then I found this
Fuel tank access cover, well these are sold out, I ended up getting the cover with a pick up tube welded to the center. Cut the tube and put a bolt with a "o" ring in the fitting. Spent Friday evening and some of Saturday morning working this. Had to get the allen head screws all about the same thread then maybe turn each one, a turn or tow till they got all tightened. Of course before that, I cut the opening, removed the rest of the fuel and crap with a vacuum. Actually did that a few times because I had to enlarge the bolt holes in the tank.
So now I have a clean tank, put fuel in, turn the key and let the new pump "prime", crack the injectors and see fuel, maybe? Go to start and she runs real ruff, never smoothing out. At this point I have the running board off the tractor so not too much crawling under it to see the pre pump filter and pump. Well, I see the pre filter is not really filling up. So, the issue is now that plastic block that the fuel tank line, two vent lines, the supply line and return line all run into. If you have one of these older BX2200s, its on the lower inside right side "kinda behind the right rear tire, inside frame rail". Just for the heck of it, I pull the line off the fuel tank, yep got fuel. I pop a vent line off the top of that plastic block, yep fuel there. So I pull off the line to the engine off that block and..... nope, no fuel. Insert a piece of zip tie and Bam! small black thing come out and now good fuel flow. So button all the lines back up, replace the post pump filter ( closest to the injection pump) turn the key, she primes, and then fires off, rough at first them smooths out like normal.... RUNNING!!!!!
So after almost a month of Little Mule sitting on the front side of my house, She is running, I finish the job I was doing and put her to ben in the shed. Thanks for all the input gents!!
