Main 9 wire connector B7100HST old
ttfo
B7100 HST, RTV 900
Oct 3, 2012
88
Custer, SD
The 9 wire main connector in my B7100HST old has burned because of a defective part. I have corrected the problem,. but need to replace the connector. Any ideas where I can get the 9 plug connector. I found some, but the wires were to small.
Thanks
3,161
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
There's no reason you have to stick with the original connectors- cut them off. Plenty of aftermarket options out there.
ttfo
B7100 HST, RTV 900
Oct 3, 2012
88
Custer, SD
Thanks, do know of any suppliers. I been looking, but most that I can find are only 16 gauge wires.
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
443
182
Attalla Alabama
mossycreekoutdoors.com
Jim L.
888
182
Sounds like you are determined to match the original connector. Measure the dimensions of the shell, pin to pin spacing, sizes and types of pins.
Then look at the connectors at eastern beaver on the internet. That connector is Japanese, used on motorcycles or sport vehicles. Modern connectors have moved to sealed connectors for automotive use.
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
284
235
Wahkiacus, Washington
When I rewired much of my B7100 last year I had the same problem with that and some other connectors but the deterioration was mainly age and them falling apart. I bypassed around them with insulated spade connectors and colored shrink tube for each of the conductors. Some places I eliminated connectors as there was never a need to open the circuit anyway. I can't remember when all the electricals worked all at the same time and when needed. 🏆
torch
Jun 10, 2016
2,886
1,133
Muskoka, Ont.
I was going to suggest Eastern Beaver, but Jim L. beat me to it!
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
What are the gauges of the wires and qty of each gauge in that connector?
Thanks to all. I think all that info will help me decide which options and how.
I was going to suggest the Deutsch DT Size 16 8-position and the DTHD Size 12 1-position connectors. Split the heavy gauge wire off from the rest of the smaller gauge wires.
ttfo
B7100 HST, RTV 900
Oct 3, 2012
88
Custer, SD
thanks i will look into them.
