FEL while mowing.
Botamon
Mar 26, 2018
401
755
Winnemucca, Nevada
Thanks for all the responses. Just re-enforces my thoughts on mowing without the FEL getting in the way. Plus I have a lot of obstacles to get around like trees, gardens, and outbuildings.
Yup. Having the FEL on the tractor makes it 6' longer so harder to get in tight spots. In some spots I'm able to raise the bucket to get closer to a corner (over a fence, for instance) but in other spots that's not possible.
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
209
334
Grayling, MI.
I thought if you kept it down low it would be added weight also lowering your center of gravity.
Yes, you are correct. Problem is it sticks out quite a way and in a tight spot it may make that portion of the mow almost impossible to get to.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
54
46
Lakes Region, NH
The OP was asking about mowing with a loader on a BX or B in which case the loader does not add anything close to 6 ft of length, more like 3 ft and less than half that if you take just the bucket off.
David T
BX23S TLB, Pallet fork, 60" Rotary Belly Mower RCK-60B-23BX, 72" 3PT Pine Straw
Mar 8, 2022
17
25
East Garafraxa, Ontario Canada
Just curious as to how many people that have a BX or B with a belly mower leave the FEL on while mowing? I usually do any loader work and when time to mow I drop the loader. Like I said, just curious.
I just recently got the belly mower. I built the backhoe dolly specifically to be able to remove it when it's not specifically needed. The FEL is a piece of cake to take off and put back on. The property I have (2.5 acres) has some pretty significant hills that I need to mow. The BX is very easy to handle without all the added weight and length. Not to mention the steering is a dream with no frontend weight. To say that taking off the FEL is a waste of time just speaks to how unfamiliar you are with removing and reattaching it. I have not timed it, but no more than 3 mins on or off. The BX climbs hills like a champ when unhindered by the FEL.
johnjk
Apr 13, 2017
1,680
1,840
West Mansfield, OH
No mmm on the B3200 but I leave the FEL on when I brush cut. It works great to up end the field olives and allow the rotary cutter to chop them up.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,786
2,171
Near Lancaster, PA, USA
When I had a brush hog and went through tall stuff I did use the FEL to find things so the bush hog didn't.
dlsmith
BX2230, LA211
Nov 15, 2018
1,295
893
Goshen, IN
In the eight years I've had my BX, I've never taken the FEl off. It comes in handy when mowing and stopping to trim low hanging branches. Cut them up, toss themin the bucket, and next trip past the brush pile dump them off.
Bearcatrp
Mar 28, 2023
1,003
634
Minnesota
I leave mine on. Have yet to remove it since buying it. Just remove the bucket and keep it as low as possible. For those tight areas, that’s what my weed whacker is for.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,506
530
Always mow with my loader on. That way there when I come across the numerous branches that always fall in my yard, I just stop and throw in bucket.
That's not the reason I leave it on, but it does work for that. I just can't be bothered taking it off. My loader has never been off my B2620. I just use it way too much. Pretty much any time I start that tractor I use the loader.
WI_Hedgehog
Apr 24, 2024
848
1,182
Milwaukee, Wisconsin, U.S.A.
...when I come across the numerous branches that always fall in my yard, I just stop and throw in bucket....
My girlfriend picks up the fallen branches around the shack, if she didn't I'd leave the bucket on and engage the Seat Switch Bypass so I could hop on/off easily while mowing. If I had a real tractor maybe I wouldn't be inclined to do that, but I don't so I do.
:unsure:
...or would, since...I'm confused.
WI_Hedgehog
Apr 24, 2024
848
1,182
Just curious. Why are the back tires backward?
Lack of coffee that morning.
Actually, it's because I didn't know better. I thought it would pile all the mud in the middle of a rut (if it dug one) thereby filling the rut back in, BUT there was a thread on which way to mount grippy tires and...I've since learned differently.
Both of the OEM front tires are mounted on the rim the same way, so one of them is always backwards...however one is always forwards, so... I guess I should re-mount one so I can mount them both on the tractor the wrong way. :unsure:
chim
Jan 19, 2013
2,786
2,171
So, if you swapped the rears they'd both point in the "right" direction, but doing that in the front wouldn't fix anything:)
WI_Hedgehog
Apr 24, 2024
848
1,182
Right. Currently. :unsure: Or left?
If I swap the front right and front left then what happens is "the other one" points backwards, meaning up front one always points the wrong way. Since the front differential doesn't lock when in 4WD (learnt that here) it reduces traction on both sides.
So I need to de-mount one tire from the rim, mount it back the same way I took it off, realize five minutes later I messed it up,, de-mount and re-mount the rubber properly after double-checking five times, and THEN I can mount both front wheels pointing the
chim
Jan 19, 2013
2,786
2,171
A few years ago I had the garage we used at work mount new tires on rims for the Ford. We had a history of pranking each other, so when I brought the tires/rims home to mount them, I sent the pic below to the garage asking if they were using drugs. To me it looked like the fake photo that it was with the jack in place. Apparently not to them. I was told they had a heated conversation about who screwed up Jim's tire.
Daylight
BX231, Ortolan T10
Feb 25, 2021
469
836
Mowing only once a year (just once in the last 7 years did I mow twice, and one year not at all), I left the loader on when I was still using the MMM, and still leave it on now that I have the flail mower, to push low-hanging branches out of the way.
Old Machinist
May 27, 2024
499
546
NE FL
My LX rides better with the weight of the loader on so I just leave the bucket off.
