Steering center moves continually.
captmikem
BX2660 MX 4800 and a bunch of attachments.
Mar 16, 2017
153
23
SW Washington State.
Today I had to travel down the road about 2 miles with my MX48. Full throttle in High (Hydrostatic drive). I was in 2WD, I noticed I had to keep turning to the left a bit. I timed it over 60 seconds and the steering wheel changed a full 120 degrees counter clockwise to keep straight ahead. Is this normal?
Stopped, with the engine shut down I can turn the steering wheel left or right, it has resistance then none then resistance then none as I turn the wheel either way, the front wheels do not turn as I am doing this turning of the steering wheel.
Thoughts?
M
nbryan
Jan 3, 2019
1,425
944
Hadashville, Manitoba, Canada
A crowned road with a little loose or insufficient toe-in adjustment will pull you to one side while driving. The hydrostatic powered steering "gives" a bit under constant turning pressure, so having its center point rotate through 120 degrees over that distance isn't surprising to me.
Check for looseness in any steering ball-joints and then measure the toe-in and check against spec. An adjustment may help alleviate the constant drag to one side.
11,083
Could be normal or it could be the center seal on the steering cylinder is going out.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
Hydro steering walks around. Ever notice the steering wheel center cap on tractors with hydro steering usually have a design other than a manufacturer's logo that can be considered "right side up"? Many people wouldn't notice the varying position of the steering wheel if they didn't have a suicide knob.
7,268
Thoughts?
M
My L3901 behaves the same on our county road.
SDT
Apr 15, 2018
3,684
1,408
Thoughts?
M
Sounds normal to me for reasons already posed.
Yes, I would check/adjust tire pressure and verify that neither brake is partially applied.
captmikem
Mar 16, 2017
153
23
Previously I had a leak in my left front tire that I thought I had fixed. It still leaked slowly, and I had not found the source of the leak. Because I might leave my trator at the other property for a few days I put extra air in that left front. I think that may have exacerbated or caused the problem (if indeed there is a problem). Thanks for all the input. I am not going to worry about it unless it gets worse. But I will check for looseness in the steering ball-joints and check the toe-in to make sure it is within the 2 to 8 mm spec.
Thanks again.
M
