Front ballast for L4760 when using Woods TKP84.40 mower
Jamone
Kubota L4760 cab, LA1055 loader with 4-in-1, Woods TKP84.40
May 23, 2025
Hi, I have a L4760 cab on order with a Woods TKP84.40 finish mower (820 lbs operating weight).
On my current tractor (Deere 2038r), my 700 lbs flail mower is slightly too heavy to operate without the loader on, or front weights. Steering while accelerating isn’t possible. But flat ground mowing is possible.
I’m wondering if yall have an idea if I’d need front weights on the new tractor for this type of use. If so, any idea how much weight I should get? I will have a loader, but I don’t really like keeping the loader on while mowing.
The other thing that isn’t clear is if you need to add a weight bracket on the Kubota or not.
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
457
244
Randolph county N.C.
My 4760 came with front weight bracket built into the grill guard guard.
IMO I think you will be okay without front weights, My 7ft bushhog weighs about the same as your finish mower but extends further from back of the tractor. I leave loader on but no bucket installed and I have no problems operating in hilly terrain.
SDT
multiple and various
Apr 15, 2018
3,312
1,102
SE, IN
Probably will not need front weights when on level ground.
The FEL grill guard will accept 4 or 5 front weights which will be enough if needed in most circumstances.
Be advised that front weights, whether mounted on the grill guard or on the optional front weight bracket, must be removed before installing them FEL.
Jamone
May 23, 2025
Great, thanks for the help! I do have a couple hills. But I’ll be mowing those, not transporting the mower on them. So weight won’t be an issue on them. It’s nice I don’t need any extra brackets to use weights if I end up needing them for something.
SDT
Apr 15, 2018
3,312
1,102
SE, IN
I would simply try without weights and add weights only if necessary.
They are expensive.
Jamone
May 23, 2025
They are expensive.
The reason I was asking was if it turned out I absolutely would need them, I’d have a chance to have them financed in with the tractor.
But since it sounds like I probably won’t, then it’s worth trying without first.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,751
2,117
Near Lancaster, PA, USA
My BIL has a Woods 990X on his L4740 and it works fine without front weights. Pretty sure it weighs about 1-1/2 times what your deck does.
SDT
Apr 15, 2018
3,312
1,102
SE, IN
FWIW, front weights were mandatory on my L6060 with Woods BB720X on anything but level ground. Still carried the front end from time to time on steep areas with the maximum 5 weights attached to the FEL grill guard.
No, I never mowed with FELs attached.
chim
Jan 19, 2013
2,751
2,117
My next door BIL and I out mowing.
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
172
182
Two tractors mowing the same area? Nice.
Must be a good sized area, or it gets done really quick.
chim
Jan 19, 2013
2,751
2,117
Our properties meet where the tractors are shown. We each have about 3-1/2 acres to mow plus my BIL has 5 small fenced meadows and moves the cows between them for grass control:) I can do 3-1/2 acres between 75 and 90 minutes. It depends a lot on how creative I am with the mowing pattern. (Did it once in an hour but it bordered on equipment abuse)
For the lawn closer to his house he always uses a large Ferris mower. I use the Kubota for everything. Now that our flowers are blooming and we mulched recently I do make a pass where the grass/mulch meet with my 20V string trimmer.
