bogging down
BallEE2023
Kubota L3800 D
Feb 9, 2024
Glasgow KY
I have a 2013 L3800H, and the motor bogs down when going up uphill and/or or bush hogging. fuel filter is new oil filter new hydraulic filters new
I just sprung a leak on the radiator hose it got a little hot but did not make it to the red mark. this happened wednesday. it has a little smoke every now and then. oh and the hydrostatic has been rebuilt.
biketopia
Feb 15, 2024
318
300
Warrenton VA
What range are you traveling/cutting in? If in High, you really should try medium, maybe even low depending on how thick of stuff you're cutting and the slope. Just traveling if I'm in High and go to drive up my slight hill to my parking area mine will bog way down.
BallEE2023
Kubota L3800 D
Feb 9, 2024
Glasgow KY
in medium but lately in low and still bogs down
i cut about 4" to 6"
old and tired
L2800 HST; 2005; R4
Lots of questions... What range and how high is the grass. How steep of a hill?
Hate to ask but did you leave the parking brake partially locked down? (just things to check, I've done that even today!)
Would love to hear more about "....the hydrostatic has been rebuilt." How many hour before it needed it? Basically, it's the first one I've heard of... any idea why?
6,816
Sounds like a fuel delivery problem to me.
What RPM are you running in?
Is the fuel tank full?
Sounds like your change fuel filters regularly?
Just a thought - - I think (?) your L3800 has a fuel/water separator housing where the filter is.
If so (?), there have been many cases where the 90-degree fitting on the inlet side of the housing gets jammed with some crap.
Restricts fuel flow.
The others have asked a lot of the same questions I would have asked. Sounds like they're heading in the right direction.
BallEE2023
Kubota L3800 D
Feb 9, 2024
Glasgow KY
hillside about 45-55
yes i haveleft the brake on but it does it even without it on
All I know is that the dealer i went to saisd that the hydrostatic was worn out and replaced seals and other stuff, that is all i know
