Fuel shut off cable
ferguson
L3130
Jan 19, 2022
322
126
w.v.
L3130 can you install a fuel shut off cable to over ride fuel solenoid. / Having electrical problems. / Need to use tractor. / Have changed "ALL" switches , OPC timer , Starter Relay , ignition switch & the fuel shutoff solenoid.
jaxs
B1750HST
Jun 22, 2023
1,000
773
The solenoid doesn't know whether it is being moved by a cable or a finger, move it with your finger and expect identical results if a cable is used.
9,743
Just remove the solenoid and put some good tape over the hole, or make a quick plate to cover the hole.
9,743
The solenoid movement is not accessible outside the engine.
9,743
In view of the fact he already replaced solenoid once, Ferguson knows how to gain access.
You can't get to the solenoid rod to move it with your finger when the solenoid is attached to the engine.
