hydraulic delivery pipe removal
Farm Ma
Kubota L35 TLB
May 21, 2025
L 35 tlb, there is a leak in the hydraulic delivery pipe (120 on schematic). I have it disconnected on both ends. Does anyone know how to get it out? I'm hoping not to have to completely disassemble the front end to pull it out & replace it. Thanks
3,821
2,379
120 on this diagram from KubotaUSA is a bracket. Is the line you're referring to on here?
10,966
Yes! I've removed everything I can, I got better movement, but can't remove. Thinking about cutting it and using a rubber tube with clamps. Any thoughts?
Ok that pipe is not delivery, it's suction.
So yes, you could just put a piece of hose over where it's leaking and make it work.
