L2502 PTO noise
Orange man
Kubota L2502 LA526 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
259
169
WNY
My new L2502 PTO makes a strange noise at times, it makes no noise without a load on it but when using the finish mower it will make a whirling, rubbing sound. Works fine and does not slip, Just wondering if anyone with a L02 series tractor has noticed it. Thanks
11,015
Let me guess, L2502DT
And it does it when you change engine speeds too.
Most likely over running clutch:
Orange man
Jul 23, 2014
259
169
WNY
No, I should have said it is a HST
PhilHtx
L2502
May 18, 2025
11
Eureka Springs, AR
Got the same issue with my new 2502 (HST) sans rubbing sounds. Figured it's internal hydraulics when the brush hog is under load. It is loud enough to require hearing protection.
3,077
Does it do it ALL the time or just with a load on the PTO?
If there is a mower on the PTO, does it make the noise when the mower is spinning without any mowing going on or only under a mowing situation, or in both cases?
Orange man
Jul 23, 2014
259
169
WNY
Mine can make the noise without mowing, just stopped, but I can be mowing and it makes no noise, Mine only has 7 hours on it so maybe just needs to break in.
