Plastic rivet pins for BX2380
ZipFunk
2380, T1880
Sep 10, 2021
26
This isnt a high priority question by any means but I'd like to take the rubber 'floor mat' off my BX 2380 sometime and clean under it.
I assume the rivet pins will break when I try to take the mat off and I'm wondering what pin size I can buy.
I've googled it and I get no real size, just Amazon hits really.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
837
747
E.
I don't know but if you pull one and take it to your local NAPA or whatever nearest autoparts depot has they will match it to their stock (either loose ones or bagged ones) and tell you the exact size / description.
ZipFunk
2380, T1880
Sep 10, 2021
26
Good plan. I’ll do that. Thank you.
Mowbizz
Bx25d
Aug 19, 2021
562
325
That rubber caused my “step” (which the “floor” is called) to rot out under my feet because of standing water. Bought a replacement STEP and had it Line-X treated before putting it back on. Now the step will outlast the tractor.! 😊
xrocketengineer
Nov 14, 2020
848
801
Merritt Island, Florida
When I pulled mine out, they all survived. That sounded weird.:oops: I found that my floor had some corrosion. When I removed the floor mat, non of the plastic rivets broke. However the floor was really badly corroded since the paint was bubbling and peeling. Fortunately, the floor was replaced under warranty. I assume that Kubota agreed to replace the floor since the rest of the sheetmetal on the tractor had zero rust.
ZipFunk
2380, T1880
Sep 10, 2021
26
Thanks for this. I haven’t bought them yet so I’ll try to pull them out carefully and see if I have the same luck.
