B7100 non-HST dipstick
JRHill
Orange: B7100 Std and Woodmizer; Green/yellow JD Buck, Gator and 410j.
Apr 26, 2016
281
234
Wahkiacus, Washington
Not that it makes a difference to HST to gear units but please, someone, measure the length from the dipstick seat to the upper of the oil level? Pretty please? Some years back the seat slipped on the dipstick and I'm and just guessing. I'm sure it's too full from where I guessed. Not that I've had a problem but I am sure I'm over filling it. If this is the biggest problem I have today I am fortunate: I hired a father/son team of guys a week ago. We don't have many choices. They wagged their heads that they understood but did exactly the wrong thing. I don't have them service my equipment. Bwhh-hahh.
I could go to about any shop and get a native of the U.S. and they would be about as brain dead.
OK, back to the dipstick....
3,057
Here is the info - I hope it is what you need
3" mark at stopper to deck - full mark at 5 5/8"
So - 2 5/8 down from top on level ground is full ;)
( THis is on an HST model btw)
JRHill
Apr 26, 2016
281
234
Thanks for the pix. I've always wondered what the 537 and 364 meant. Different models? And the other marks?? Looks like I guessed close enough to just use the top mark for full when level: 1000000445.jpg
3,078
@JRHill
I think there is only two actual LINES on the dipstick. The very upper one is “full” and the very lowest one is “low”.
The rest of the stamped marks is a part number = 15371-36411. But that is not the part number you would be able to buy. It is some stock part number for the factory when they built the engine.
But the ones do look like some line also!
JRHill
Apr 26, 2016
281
234
I've only had this machine for 34 years and it was 15-20 years old when I got it so I thought I should figure this out. Especially when the stopper slipped on the stem.
I can't say it's kept me up at night. :unsure:
Love this forum and all y'all!
TerryKing
B7100HST-D
Aug 18, 2024
178
119
Topsham, Vermont USA
arduinoinfo.mywikis.net
OK THAT's helpful. With new Kubota oil in my B7100HST I can not read the level on the stick. It's all so shiny (Even with my reading glasses on). I was thinking of calibrating a bamboo chopstick so I could quickly check the actual level. Now I'll DO it.
Thanks!
torch
Jun 10, 2016
2,879
1,125
Muskoka, Ont.
Look again, those lines before and after are "1", so it reads 15371 36411 -- the Kubota part number for that dipstick.
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Milwaukee, Wisconsin, U.S.A.
All those numbers! You apparently weren't in the Marine Corps... 🤣
....With new Kubota oil...I can not read the level on the stick. It's all so shiny (Even with my reading glasses on). I was thinking of calibrating a bamboo chopstick so I could quickly check the actual level....
Hold the stick in one hand, paper towel in the other. Press the stick against your finger and lay it on the paper towel. Wait 10 seconds, the oil will bleed into the paper towel and you'll see the current oil fill level. Pinch the paper towel around the stick with your thumb, wipe the stick, put it back. (If I lived in Nevada and had a third arm I'd take a picture.)
WI_Hedgehog
Apr 24, 2024
1,129
1,646
Brilliant! I'll use that approach for OtherStuff too. THANKS!
It works well, even with new, clean, thin oil. It only takes a few seconds (slightly longer with new, almost clear oil), but seems like ten. Don't need much light to see it either as white paper goes clear-ish. Does not work all that well in heavy rain if outdoors. 😂
