B1750 Mower Issue
Abunk
B1750
May 18, 2025
Cape Cod
Hi. Helping out family using the mower deck on our B1750 to mow about 6 acres. Also doing some work removing small rocks from a newly filled area, hand raking and collecting in the bucket to dump on our growing rock pile.
The mower suddenly seems bound up. I had been using it (almost) no problem until after dumping some rocks I could no longer move forward or back without stalling. I'm still getting used to the levers and shifters, but I used the lever to raise the mower deck and everything seemed fine for the moment. Not sure why it was low at that moment. But I was able to run the machine for a few hours and put it away. Yesterday I wanted to mow and I could not because every time I engaged the mower the tractor wanted to stall out. Same situation as before except raising the belly mower didn't fix the problem.
I know I need to inspect the mower unit itself to see if anything is causing it to be bound up. My question that could save me time is this. I don't fully understand all the levers including whether there is a Mid PTO brake. I've been using the parking brake on a slope. Are those connected somehow. I've engaged and disengaged the mid PTO for the mower 4 or 5 times hoping it would start working. I see there is a differential lock lever, a 2wd to 4wd shift lever. Does the mid pto require these other setting be set a certain way? Like only 2WD or only 4WD? Differential lock vs unlocked.
Printing off sheets from the manual and heading over to inspect mower deck as best I can and to check settings on levers.
Thanks for any help or advice.
Andrew
BTW my B1750 uses a shift lever for forward reverse etc. I saw another owner here with foot pedals for forward and reverse. So different setups for the B1750 I guess.
SDT
multiple and various
Apr 15, 2018
3,312
1,102
SE, IN
Andrew
Mid mount mowers are designed to mow lawns. They are not designed to mow untended areas. What are you mowing?
Apparently, your gear drive B1750 is not a HST. Accordingly, drive is controlled by a foot clutch and gear shift levers, rather than a HST (foot) pedal. The 2/4WD lever and differential lock pedal operate independently of the clutch and gear change controls.
It appears that your MMM deck is prevented from turning. This can be the result of spindle bearing or belt failure, other damage or, more likely, debris of some sort clogging the deck or belt.
Remove the belt covers to inspect the belt and inspect the underside of the deck for debris, something wrapped around one or more blades, or damage.
Post back.
Abunk
B1750
May 18, 2025
Cape Cod
Post back.
Thank you for the reply SDT. I feel lucky because it worked fine all morning. After putting it away yesterday I reached under the mower and pushed the blades. Seemed like a lot of resistance at first but then started turning more easily. That might have freed it up. Today I backed it out and examined the diagrams for all the levers. Then tried the mower and it ran fine. I got to use the hi-speed lo-speed setting. I'm mowing a slope today and have to go straight up and then back down. Problem was I'm prepping to seed and it was somewhat bare and dusty, with wind of 25 so I needed speed going up and a nice safe crawl without mowing backing down. Otherwise I'd have a face full of dust the entire time especially at a crawl. The shifting was pretty smooth. Good to get more familiar with this machine
Most of the mowing is on land that has not been tilled in ages. We grow Christmas Trees on a big chunk so the area around that is pretty flat. There is an area that's been taken over by wild raspberries. One of my sibling got the mower tangled up in it. I tried it in small strips and didn't have a problem with them getting tangled.
Once i get this slope area seeded I'll be looking into removing the belt covers to keep the belts as debris free as possible. Thank you SDT for the reply.
SDT
Apr 15, 2018
3,312
1,102
SE, IN
Again, your MMM (belly) mower is designed to mow lawns, not untended area. Though the MMM sold with the B1750 is one of the very best finish mowers, it will not hold up to duty more suited for a rough-cut (bush hog) type mower.
I strongly advise you to remove the belt covers so as to grease all 3 spindle bearings, the belt idler wheel and idler wheel pivot. Be certain to grease all 4 of the gauge wheels and check the oil in the gearbox as well.
Finish mowers do not clear well when traveling in reverse, especially when discharging into tall uncut cover.
Abunk
B1750
May 18, 2025
Cape Cod
I will check out the belt covers and do a search for a manual. This might not be the original mower. I'll identify what model it is if possible. I recall the original had issues and might have been traded for another one. I wonder if a brush deck is available for this tractor.
Bee-Positive
BX1880, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
413
402
Amsterdam, NY
Given the age of the tractor do you remember the last time the deck had any regular maintenance? Clean it up and as SDT said, GREASE it up!!! Replace the belt if needed, sharpen the blades, etc.
SDT
Apr 15, 2018
3,312
1,102
SE, IN
Your tractor can operate a three point mounted 42" rough-cut (bush hog type) mower in most conditions and a 48" one in some conditions.
Abunk
B1750
May 18, 2025
Cape Cod
The Kubota was new in 1991 and we purchased it used in 2018 for $7500. It came with a 60" MMM but that was replaced with a different MMM that was supposedly 6" smaller than the original. The original had some serious issues, probably from lack of maintenance and mis-use and the mechanic said it wouldn't be worth us paying to fix it. I did take some pictures which I'll upload. It looks like one of the covers was intentionally cut open. I took both covers off and cleared grass and leaves out. I did not see any model # but there were some informational labels including one that was partially cut away when the cover was cut open before we owned it.
SDT
Apr 15, 2018
3,312
1,102
SE, IN
Similar design MMM decks for your B1750 were available in 54" and 60".
The right side belt cover on yours has been (poorly) cut away in order to install a gearbox for a powered grass catcher that has been removed at some time in the past. The 60" deck on my B1750 has the optional grass catcher but I have not used it in decades.
The right rear gage wheel assembly is missing from your deck and the left rear gage wheel is worn out. Your deck is a terrain following deck and proper gage wheels are needed for proper operation.
There is a grease fitting for each spindle on the top of the deck that must be greased regularly as the bearings are not sealed. There are also grease fittings on the idler wheel and the idler wheel pivot.
Too bad you did not keep the original MMM deck for parts.
Abunk
B1750
May 18, 2025
Cape Cod
Here's the specs for MMM's that fit your B1750 according to
www.tractordata.com is an easy place to start and get some model #'s to look up parts if you don't have a Work Shop Manual (WSM).
Thank you for the reply Bee-Positive. I do have manuals and parts list. Is there a part of the forum where these get posted. I don't remember where I found these years ago but if they're not on this site I'd be glad to upload them.
SDT
Apr 15, 2018
3,312
1,102
SE, IN
I forgot about the 48" model. It was used with the B1550 model. I doubt that anyone bought it for the 1750.
I bought my B1750 and 60" MMM new in 1994 and have all of the manuals, including the grass catcher manual.
Abunk
B1750
May 18, 2025
Cape Cod
Thanks SDT for explaining the cut away. There is lot's to know. As I mentioned to Bee-Positive above I have manuals in pdf form that I could upload. I noticed the WSM Manual ( 600 pages) has directions for maintaining the mower decks and instructions for removing and re-attaching them. If I have the 54" deck then it slides out laterally. It's not a drive over like the other models.
I'm not clear on whether I need to remove the deck to do all the maintenance. I was thinking it would make it easier until I saw something about needing to detach the front end loader as the first step to installing the mower deck which sounds like a can of worms waiting to be opened.
I shouldn't do anything until that right gage wheel is put on. The mowers 326 lbs. won't pull out laterally very easily without all 4 wheels. I saw a Gage wheel with orange paint laying around. Hopefully it's functional enough to perform some of it's duties.
Bee-Positive
Nov 16, 2022
413
402
Amsterdam, NY
www.kubotabooks.com has the operators manual but I don't see the WSM. Maybe SDT has a suggestion? Or search on-line - you may have to pay for it being an old tractor.
Abunk
B1750
May 18, 2025
Cape Cod
My sister remembers being told the deck she was getting is 6" shorter than the original so it's go to be the RC54-B
Abunk
B1750
May 18, 2025
Cape Cod
I found 2 gage wheels laying around and assumed they'd fit the right rear position but they don't. They make contact with the rear tire.
They're basically the same dimensions as the other gage wheels. First I realized the one I picked has a bolt installed that prevents the wheel from rotating right or left. In other words it can only roll in a straight line. So that one is different from all the others. I am guessing removing the bolt would free it up to track as it wishes but don't know if that is advised.
The other gage wheel can swivel so it can aim itself as needed. The real puzzle is why the gage wheel makes contact with the rear tire. The left rear gage wheel "bracket" is adjustable. The right rear "bracket" is not adjustable.
IMG_0357.JPG left side adjustable bracket
IMG_0356.JPG right side fixed or non adjustable bracket
IMG_0352.JPG Right side gage wheel making contact with tire. This is it's lowest setting.
On the bright side I found my grease gun (empty) and a full unopened cartridge of grease for it.
SDT
Apr 15, 2018
3,312
1,102
SE, IN
View attachment 156500 left side adjustable bracket
View attachment 156501 right side fixed or non adjustable bracket
View attachment 156502 Right side gage wheel making contact with tire. This is it's lowest setting.
Correct gage wheels. Apparently, someone locked one in the non-swiveling position to prevent contact with the rear tire. Do not know if this is necessary with Z-Bar tires and 54" deck.
Your deck looks very similar to mine except mine is the 60" version which probably provides more clearance between the gage wheels and rear tires.
If possible, set the rear tires further in. To prevent unnecessary hub wear, be CERTAIN that the adjustment bolts are TIGHT. I have the same Z-Bar tires as do you and have no gage wheel-tire clearance issues.
FWIW: It is almost impossible to over grease the gage wheels and yoke pivot shafts. I grease mine after almost every use and have no wear issues after over 30 years of use.
Bee-Positive
Nov 16, 2022
413
402
Amsterdam, NY
In the third picture you posted the rear tractor wheel looks like it's a bit farther out than the fender, it may be just the angle the picture was taken. Could the previous owner have installed rear wheel spacers? I'm limited on how wide of a spacer I can use on my tractor before it pushes the wheel into the mower deck gage wheels. Just a thought.
