Dually valve stem extensions
JasonW
401
204
Al
I upgraded to a dual tandem trailer a few months ago and would like to upgrade the valve stems to use a regular air chuck.
I have tried two different “dually” air chucks at first and neither worked for the inside tire due to hitting the rim. I have also tried the hard extensions but they need a slight angle to go straight through the outside rim. Thin line between bending them to fit and snapping them. All rims have metal valve stems that offer no flex.
I have the u-shaped valve stems on the outside tires and those work fine, just need something for the insides. Only other ones I see are stainless braid.
Anyone have a solution to this?
7,595
I use something like this on the dual tires on my service and delivery trucks at work. They sell them calibrated for different tire pressures. And with one quick look you can tell if you are good or have an issue.
They have internal check valves, so if one tire is at a lower psi, that tire will inflate first until the tire pressure reaches the same as the other tire. Then both tires will inflate evenly.
The added bonus is one easy to access valve stem.
JasonW
401
204
Al
Those may be the ticket but for $300 this will be put on the back burner.
Looks like they mount on one of the wheel studs?
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,524
1,986
Western MT
Sometimes my tire shop don't align the rims correctly. It shouldn't require a special tool if they are aligned correctly.
8,306
Good timing on this thread. I bought a 2024 F-450 recently and am picking up a new Kaufman 30ft 25k gooseneck with dual tandem axles on June 2nd. I did something clever (a friends suggestion) with the inner valve stems back in 2001 when I bought my first dually, a Super Duty F-350 7.3L, but I can't remember what I did. It was a mod that made checking tire pressure and adding air a lot easier.
