Minumum tire spacing for safe operation of bush hog
sotaylor55
Kubota L4701
Apr 16, 2025
Stoughton, WI
My bush hog (Bush Hog BH216) manual states that the tractor tires must be spaced at least 60", inside of tire to inside of tire. My tires (of my Kubota L4701) are currently spaced at 36" and I don't see how to make them wider (the rims are already set so the tires sit as wide as possible), let alone 24" wider. Besides, if I set the tires an wider, they would be wider than my mower which I don't want.
What do I do? Is it alright to just ignore that guidance? It seems like anyone with my tractor and a 6" mower (i.e. a lot of people) has the same problem.
Thanks in advance.
#40Fan
471
324
Does the manual specifically state the rear wheels?
Wondering if it isn't talking about the front/rear distance which would be called the wheelbase.
ken erickson
Nov 21, 2010
1,334
2,372
Waupaca Wisconsin
That 60 inch minimum dimension does not make sense to me for your tractor and BH216.
Can you take a screen shot of the manual with the 60" minimum tire spacing and share here? I do not doubt you but wondering what version manual has this information. The manual I pulled up seems to be the latest version that Bush Hog has available as a PDF on their website.
I pulled up Bush Hog's user manual for the BH200's series which covers BH216 and this is the only thing I can find concerning rear wheel width spacing.
Copy and pasted from the operators manual.
"The tire spacing of the tractor must be sufficient to maintain stability on the type of terrain where it is intended to be operated and for the type of implement that is being operated. Always refer to the tractor Operator’s Manual or consult the tractor’s authorized dealer for instructions on sufficient tire spacing or to change tractor tire spacing. Operating without sufficient tire spacing to maintain stability can result in loss of control of the tractor, a rollover accident and death or serious injury."
page102image257780048
This manual is published 12/21
3,570
2,166
Thanks in advance.
Sometimes you just gotta use your best judgement. That would be a big tractor to have 60" inside-inside, and it would be wider than the mower. Sounds like corporate CYA.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,007
2,493
Near Lancaster, PA, USA
"Sounds like corporate CYA"
Sure does. With R4's on a tractor that size it'd be almost 8' wide on outside of tires.
10,321
No kidding! The inside to inside spacing of the tires on my M6060 with the wheels set at the 2nd widest setting is only 45".
5,576
Here it is. Manual is from 2019.
I’d go with the metric dimension written in the manual rather than the imperial dimension. As long as they’re at least 1.5 millimeter apart you should be fine per the manual. Might have trouble hooking up the PTO but the manual says 1.5mm is sufficient.
As snarky as that may have sounded, that’s what the manual you posted actually says and I think that’s instructive as to the reliability of that specific portion of the manual. 60” inside to inside between the tires with R4’s or turfs is absolutely ridiculous. You’re fine with them as is.
Not saying you can’t roll the tractor. Some people can roll a Timberjack running high flotation duals. If you’re mowing stuff that’s got a good bit of slope, loaded rears will help stability and remember up/down slopes to the degree possible, not sideways on slopes.
10,321
I have a Land Pride RCR1884 and there's nothing in the manual about rear wheel spacing, just a hp range. I think that Land Pride assumes that if you tractor has the proper hp then the spacing of the rear wheels is likely to be commensurate with safe operation.
Dustball
2016 B2650HSDC
Sep 15, 2023
484
352
Hudson, WI
1.5 mm would be incorrect also.
I'm assuming it means 1.5 meters. 1.5 meters is 59 inches.
10,321
I would suspect the newer manual , available on line, was updated just to remove that 60" minimum tire spacing! lol ;)
I don't know what Kubota tractor would have a 60" inner tire spacing. Maybe an M7 or M8?
10,006
7,164
Yeah, this is baffling. I’m not sure that any but the larger ag tractors have an inside width of 5’.
like others surmised, bet it’s a CYA issue.
PS - Or incorrect as Wolfman points out in the previous post.
Grandad4
Apr 5, 2016
408
159
Greensboro, NC
1.5 mm. = about 1/8 inch
1.5 meters, maybe? Which happens to be almost 60 inches!
6,319
Thanks in advance.
Ignore that guidance.
Dan.
5,576
Yeah, I suspect that’s what they meant but it ain’t what they typed. 1.5mm or 1.5m inside to inside are both ridiculous.
5,576
That’s the point. 1.5mm is obviously wrong, but that’s what they put in the manual. 60” is almost as clearly wrong as 1.5mm.
