Canopy/sun shade options or designs?
couleedude
Kubota L2502 Tractor Package
Dec 17, 2024
52
40
Grand Coulee, WA
I see many on the internet, mostly plastic or fiberglass, but I am leaning toward making my own with shade cloth or sunbrella material. Possibly a PVC frame or aluminum, EZ on and off for storage, etc. Using my boat bimini top as a general design idea.
Has anyone come across something like this, or have one, and can you share the design or photos so I can copy it without having to re-invent the wheel?
David T
BX23S TLB, Pallet fork, 60" Rotary Belly Mower RCK-60B-23BX, 72" 3PT Pine Straw
Mar 8, 2022
22
30
East Garafraxa, Ontario Canada
Been thinking about the same thing. Fabric seems the way to go as I have to lower my rops to store the tractor and around a number of trees on the property. Shock corded poles from tents??
7,717
I made a canopy a few years ago and it's not pretty but works fine. Cost zero! Neighbor had a 9' umbrella that the wind turned inside out and he trashed it. I took the arms and used them for the frame. Had some canvas pieces I used for painting shutter on so I used that material over the frame. Used zip ties to anchor the canvas to the frame. Backside of frame, I weld some bracket that fit inside the ROPS when it is folded down and the rubber plug is removed. This mount was made so the tractor fit into the shed I keep it. There is not enough headroom for the ROPS up under there, so I leave the ROPS down all the time anyway. I can put it on and off the tractor in a few minutes.
I might get a couple of pictures if interested.
3,091
Golf cart tops are typically cheap - making the frame take a bit of skill.
Hoserman
Kubota BX2380 Land Pride Box Blade
Aug 1, 2022
210
339
Grayling, MI.
I'm not trying to be a wise guy, but with all the trees and low hanging limbs I have to contend with I would have to get one of those stupid looking umbrella hats. Any kind of canopy for my 2380 would get busted up in no time.
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Wish that's what I would've done.
I was out $500 and had something that was 2 feet above my head and only gave me coverage if I was cuttin at high freakin noon!
Angled it down a bunch which help a little bit.
5,564
All you need now is a margarita.......
Reactions: 6 users
Bearcatrp
Mar 28, 2023
1,396
1,013
Minnesota
UTV (side by side) tops are fairly cheap. Have looked at ones made for my 1880. Nuts for what they want.
couleedude
Dec 17, 2024
52
40
Grand Coulee, WA
Good suggestions and ideas...
I am thinking a simple rectangle frame, maybe with a couple of cross supports (maybe, if needed). Wrap shade cloth around it and use paracord at the edges and connect them across the bottom of the frame. If I put in an adjustable bracket, I could move it forward, backward, angle it down, or just take it off with the turn of two T-handled screws. I am thinking along the lines of a T-Bag for a boat, when I think of the design.
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
204
279
Hardy, VA
+1 here. Anything made of fabric would last all of 5 minutes on my property with all the low hanging branches. Especially true when mowing the outermost edges of many of the fields.
The previous owner of my machine built a top for my B2620 from a plastic base for an outdoor HVAC unit. It has served me well enough for 4+ years now. I cannot imagine this cost him very much.
Bee-Positive
Nov 16, 2022
1,199
1,103
Amsterdam, NY
Used an old Subaru car hood, cut down the sides, supported by adjustment arms from an old satellite dish bolted into existing ROPS holes. Just barley fits in the garage while up (1" clearance). Pretty heavy but it's taken a lot of abuse from tree limbs. My son calls it the bat mobile hood.
Sidekick
Jul 29, 2023
1,287
1,866
N.Y,
I have one of the lightweight plastic ones on my zero turn and it pops right off easily. Just a thin sheet of polyethylene with a bow that makes it rigid but it doesn't break. The heavy plastic one on my bx is beat up pretty bad from hitting low branches. It just shattered the edges with a light hit.
old and tired
1,919
1,297
Here is my write-up... (as well as some other ones on that thread...)
NorthwoodsLife
Oct 15, 2021
1,410
1,475
Wisconsin
couleedude
Dec 17, 2024
52
40
Grand Coulee, WA
I second the suggestion of a side by side roof:
At $90, that is a good place to start! Framing would be easy.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
129
119
Lopez Island, WA
When I made a canopy for our 19' steam launch, I bent 1/2" EMT into 3D curves; that's really not needed here. I followed the design of commercial awnings, using a lacing rail set back from the edge underneath and grommets in the cloth edge; the fabric is laced on w/ 3/16 paracord between the lacing rale and the grommets. This keeps a suitable amount of tension on the cloth
This is likely more trouble than you want to go to, but it's lasted perhaps 20K miles of trailering.
Reactions: 6 users
