L 3901 weird display, won't start
Buffalo
L3901, FEL, mower deck
Mar 17, 2016
102
38
Oklahoma
My 2015 L 3901 is acting weird. When I turn the key to start it, the dash lights flicker rapidly and the tractor makes a loud and rapid clicking sound. The tractor does not turn over. It was fine when I parked it. The battery is good, and the cables are sound. No fuses are blown. I asked my dealer and showed them a short video, but they said they had not seen anything like this before ...
Is it the starter motor ? I do have a short video, but it won't attach ...
2,913
Upload to a youtube account and then SEND us the link!
5,506
2,213
low voltage.
check the battery voltage with a digital voltmeter. Leave the meter on the batery and then have someone try to turn the engine over. Voltage should not drop below about 10v.
open (no load) voltage should be 12.5-12.9 for a good battery.
I know you said it was good but define good. What are the voltages?
I also know you said the cables were fine. After you deem the battery good, you can then test the integrity of the cables using a voltage drop test, do it on both the positive side and negative side.
don't keep trying to crank it much with a low voltage issue. If you do there is chance the the ecu can be hurt.
Buffalo
Mar 17, 2016
102
38
Oklahoma
Hmmm. I forgot to comment that the headlights are bright, and I put a battery charger on and cranked it also. Still no joy, but the dash lights were quite bright. I'll measure the voltages tomorrow. Thanks for the comments, and the warnings. I'll post what I find out. If anyone downloads the video, I would appreciate your reaction.
9,756
I watched the video:
Bad battery connection or connections and or a damaged battery.
Have it load tested.
Remove both ends of both cables and check and clean them.
5,904
disconnect battery, with a known good battery ,use jumper cables TO the starter and nearby ground.
see if starter turns(yes there will be some sparks when pressing -ve cable to battery ).
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
258
448
Moseley, VA
I have had the same symptoms on mine and it was a poor battery connection. Take the connections loose, clean them and reconnect. Again, as others have stated, check the voltage of the battery as I have had the same when my original battery was going bad too.
RBsingl
Jul 1, 2022
485
566
Central IL
An easy way to find a connection issue is to measure voltage across the suspected point under load (while attempting to engage starter). The resistance of the bad connection will cause a fairly large voltage to be read while a good connection will have almost no voltage drop across it.
For example, if you suspect the battery terminal to connector then put one volt meter lead on the battery post and the other on the connector and have someone try to start and watch for a large reading which indicates a fault between the connector and battery post. All cables and connections can easily be tested this way to zero in on the one at fault.
Trying to read resistance with these using a typical VOM/DMM won't work because the amount of resistance needed to create a problem is far less than what these meters are designed to read. 0.1 (1/10) of an ohm creates a 10 volt drop under a 100 amp load but no standard meter will accurately measure a resistance this low. I have a Simpson adapter for my classic 260 series VOM that allows measurement down to 1 milliohm which can directly diagnose these sorts of connections issues. It uses the equivalent of a 4 wire setup so that it is measuring voltage drop across the connection and presents the result in resistance on a choice of four selectable ranges from .1 to 1 ohm full scale.
Rodger
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
282
166
NH
An Simpson analog meter, haven't seen one of them in years!!!
RBsingl
Jul 1, 2022
485
566
Central IL
I have Tektronix and HP digital meters on the bench but I also keep a couple of versions of Simpson analog meters around because I do a lot of restoration of vintage amateur radio gear. When doing alignment, a true analog meter indication is much better than the bar type simulated analog response provide by a DMM. Without an analog meter, I would rely upon a Tektronix scope for those adjustments requiring real time response.
I have a rolltop case Simpson 260 that gets used with several 260 series accessories like the milliohmeter. The Simpson 269 shown in the photo with the adapter is a less common Simpson meter and its high sensitivity 16 microamp taut band meter movement gives it 100K ohms per volt sensitivity for DC measurements providing less loading than a DMM or VTVM once you get above the 8 volt range.
Rodger
Hugo Habicht
G1900
Jun 24, 2024
1,070
1,553
Ireland
For problems like the one in this thread or finding very fast intermittent contacts I find really cheap analogue meters without any magnetic damping ideal.
imarobot
Apr 18, 2025
282
166
NH
Cut my engineering teeth on analog meters and Tektronic scopes. No longer have an analog meter, but still have my scope!
Sorry, to get off topic, I'll stop now.
Buffalo
Mar 17, 2016
102
38
Oklahoma
Geez - I started with a Wheatstone Bridge !
Y'all called it ! Thank you for your prompt responses!
The positive battery connector on this tractor consists of a strip of metal wrapped
around the battery post and secured with a bolt which can provide some tension to keep things firm. On my tractor that strip of metal was completely separated into two pieces, defeating the firmness of the connection, providing some opportunity for corrosion, and making a connection that could not provide amps under load.
I replaced that connector, and replaced the 5 year old battery as well.
The tractor fired right up!
I was mislead by the fact that the headlights worked, and the dash lights seemed very lively. 85Hokie, Lugbolt and NIW initially showed the way, but it seems like everyone contributed. Thanks!
