3rd party filters
shybuck
Oct 21, 2020
34
10
eastern PA
How does everyone feel about 3rd party filters for a BX2230? I'd like to do some spring maintenance, Kubota filters are so expensive!
JonM
Nov 29, 2024
171
348
wisconsin
oil filter and air filters not a huge deal.
but hydraulic filters... those are under very high pressure and should be kubota.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
compared to premature failures, kubota fluids and filters are pretty cheap.
Bee-Positive
Nov 16, 2022
539
552
Amsterdam, NY
I can't believe your BX2230 costs are much different from my BX1880 cost so here's my story.
Being a "new" tractor owner when I did the 50 hr. service I did what you want to do, searched high and low and bought stuff from local stores and Amazon thinking I can get it cheaper and save a few $.
This March (with 300 hrs. on the BX) I bought everything from the local Kubota dealer. Got all OEM stuff in one place at one time, no running from store to store or waiting around for delivery of the wrong (happened) or missing item(s). Could I have saved a few dollars? Maybe, but my time is worth more than that...and I'm retired and have plenty of time.
Motor oil filter ($12.80) and fuel filters ($8.70 each) were no more than any 3rd party seller. You can probably get cheaper "equivalent" filters but how much are you really saving and are they really "equivalent"? Maybe, maybe not. I've never bought a 3rd party hyd. filter but the OEM one was $22.62, reasonable considering the size and psi rating. The air filter ($16.88) I thought was reasonable also.
Kubota UDT2 was $30.15 / gal and the 10W30 Kubota diesel engine oil was $26.58 / gal. also at the Kubota dealer, which was less expensive than where I was looking on-line.
JM2C.
Old Machinist
May 27, 2024
584
685
NE FL
Dealer claimed aftermarket trans hydro filter would cause the transmission to overheat.
5,506
2,214
I work for a dealer, albeit no longer with kubota dealer
you wouldn't believe how much equipment comes through that has aftermarket fluids and filters, that has engine or transmission problems. Nobody believes it, and I'm told to keep quiet about work related stuff, so that's that.
but it happens. Now does that mean the filters/fluids are the problem? Maybe or maybe not. Maybe it's because the owners don't care enough about their equipment and they abuse it, then "maintain" it with aftermarket cheap stuff, I don't have explanantion for any of that.
similarly if I walk through a junkyard, and looking at the thousands of cars in the yard, the ones that say "bad engine" often have a bright orange filter dangling off of them...real common. Pretty rare to see one with "bad engine" on it, that still has an OEM filter. Just sayin'.
take it however you please. I've learned to use OEM stuff even on my 20+ year old equipment. Kinda hard to go wring with that stuff. One time in 34 years have I had an OEM filter ever give problem and that was because the threads were cut incorrectly.
BAP
Dec 31, 2012
3,087
1,220
Pay now! Or Pay later! People spend thousands and thousands of dollars on a tractor then they turn around and complain “How Expensive” it is to properly service them. Poor service leads to premature failures and very expensive repairs that could have been avoided by using the proper maintenance materials and methods. If they can’t afford to maintain a tractor then the tractor should never have been purchased in the first place.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,191
3,495
You bought a $7,000 wheelbarrow and want to save the equivalent of a S*Bucks cup of burnt coffee?
It's like some guys I race with. $10k motor work and a $300 helmet.
Edit- that was not meant to come across as condescending. Just that saving a couple bucks is not worth the potential future expense when it comes to filtration of hydros
9,972
I feel like you will just be wasting money now, and a lot more down the line when things fail.
You are dealing with a well designed piece of machinery and you want to saddle it with very possibly sub par protection.
SDT
multiple and various
Apr 15, 2018
3,423
1,199
SE, IN
FWIW: "You can pay me now or you can pay me later...." was in a Fram advertisement in the 1980s.
Just sayin'.
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,191
3,495
Just sayin'.
That's funny coming from a company that used (essentially) cardboard as their oil filter end caps. I wouldn't buy a Fram product if it was the only thing around me. Seeing as Advance Auto Parts is now Fram Auto, I go to the next town for stuff.
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Well put.
I have different standards when it comes to automotive service and repair.
So when it comes to my lovely beautiful tractor, I have to tell myself sometimes, "Don't be a broke d@$k!!" LOL
shybuck
Oct 21, 2020
34
10
eastern PA
OK that just about says it. This can be an emotional group. Bought my bx2230 in 2005. A great machine and I love it, never let me down. I have always used Kubota filters and oils etc. This time changing out oil, trans oil and gas filters I thought I'd see if anyone came across some 3rd party filter that measured up. I guess not!
Mitjam
Jan 14, 2013
348
420
Edmonton, Alberta, Canada
I always buy oem filters and fluids when any tractor is on warranty. Just for the fact if there was a power train warranty claim it’s on their files that oem products were purchased. In your case I wouldn’t be afraid to out source engine oil and air filter from an automotive parts store or supplier. There are hundreds of thousands of D series Kubota engines in everything from gensets to small construction equipment to reefer units on semi truck. So there will be good filters to match. I would personally stick with the dealer hst filter/filters though. But even if you don’t the odds of a aftermarket part failing and causing damage is very low. Good luck with your choices
