Bx24 won’t start. No dash lights or clicking
Mucker
Bx24
Nov 4, 2022
11
Washington
I’m having trouble finding the OPC switch location to check it. I know the location of the other safety switches switches. My tractor won’t start. Battery is fully charged, but no lamps light up on the dash when I turn the key off. Nothing. No sounds. Dead silence I’m checking everything.
Fuses are good. Slow blow fuse checks good.
2,831
So - you check HST switch?
Flip the seat up - should be right there.
Mucker
Bx24
Nov 4, 2022
11
Washington
So it just looks like a regular safety switch? I thought it was in its own box type unit. If it is then I don’t see it. I’ve followed the safety switch wiring…
Could it be under the left side of the dash that also connects to combination switch (lights and turn signals) that sits left to the relay?
2,060
I don’t think a bad safety switch would give you the no dash lights when you turn the key to RUNNING POSITION (you stated OFF which should have no dash lights)
2,060
You might want to verify that both battery cables are clean and well connected at both ends. That seems to be the predominant problem when there are no dash lights, then it could be bad ground for the dash system or a corrosion problem at the wiring harness to dash connection.
You may want to check the connections and main fuse on the tractor wiring harness positive feed wire.
Good luck and keep asking questions! And if you are SURE it could be a safety switch then you should just ignore my comment on that!
Mucker
Bx24
Nov 4, 2022
11
Washington
I am not sure of anything at this point! So thank you! Trying all suggestions!
thatHoochguy
BX22D (LA210, BT600, RCK54-22) BX1880-1 (LA344, RCK54-23)
May 11, 2025
West Virginia
Yes try battery leads, I've had it happen. Also just seen a post about a bad key switch on here a day or so ago. I've also had that be the culprit, albeit when it's the switch usually you get some intermittent issues before it just goes completely out. I even had to clean the plug for the switch one time as well. All options to try and somewhat common depending on how its stored.
Mucker
Bx24
Nov 4, 2022
11
Washington
Will do! Thank you!
jaxs
B1750HST
Jun 22, 2023
927
707
Could be something minor, something major or might even be a combination of things. It's near impossible to tell by looking and twice as hard for guessing so I recommend starting with a multimeter to narrow it down.
