trevoroni
B6000
May 24, 2023
204
254
Almost done with the new dirt in the garden.
A couple of more chunks still have to thaw.
Reactions: 7 users
11,755
Well, although I would agree that cigarette lighter sockets are not very good connectors I certainly hope that Kubota does not listen.
I install those 12V connectors in all my vehicles. Remember: it is very easy to create 5V 1A from a 12V 15A socket. The other way round is way tougher ;)
What do you connect to those outlets? It's been many years since I had any device that requires a 12V cigarette lighter plug for power. I bet that most owners these days only need to power a cell phone or a pair of headphones via a USB cable. Kubota can leave the 12V 15A cigarette lighter wiring as is, just replace the outlet with something that's actually needed. 😂
Hugo Habicht
G1900
Jun 24, 2024
1,534
2,200
Ireland
I agree 100%, one or two pairs of USB outputs would be great. But I would like to keep a 12V higher power output.
What I typically power from those sockets is work lights (I think that was their original purpose), DC/AC converters (to 230V), laptop power supplies, small electric compressors, small electric fuel pumps and amateur radio equipment.
I replace the cigarette lighter plug with those good plugs above, the cigarette plugs are typically not reliable.
Bmyers
May 27, 2019
3,614
4,868
Southern Illinois
I hooked up the dump trailer for its maiden voyage.
Reactions: 7 users
11,755
A large step drill bit also does an excellent job of prepping the hole but most of mine have been plug-n-play into a std cig lighter hole.
I've never owned a step drill bit but you educated me with your post as to an excellent reason to own one. I've increased the diameter of existing holes in steel for decades using a mag drill and annular cutter, or tacking in a piece of steel so that I can use a hole saw that requires a small pilot hole, and even filling the hole and starting over. However, with materials such as plastic, I can see how a step drill bit would be very helpful.
7,316
‘‘Twas yesterday but I mowed again. Had a lot of rain for days on end.
I was getting ready to build a boat and collect animals for a journey…. :oops:
Can you say “squish”? I knew you could……😉
Been here 30+ years. Never seen it wet like this when I had to mow.
Reactions: 10 users
Sidekick
Jul 29, 2023
1,237
1,781
N.Y,
My yard looks worse then that with deep ruts now. Checked the rain gauge yesterday and the previous 2 1/2 days we got 3 1/4 inches of rain. My field is a beautiful yellow carpet of dandelions right now.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,694
4,437
PEI Canada
It's been wet and cold here. We had 1.25" of rain yesterday but the wind dryed things out enough to do some work this afternoon.
Got the last of the trees moved that were beside the former property line and tracked in topsoil into the holes. Dumped more down the line and I'll level it of with the rear blade or landplane later in the week.
Reactions: 9 users
7,316
Similar, someone said their rain gauge showed 4.25” through Saturday morning.
Thankfully I was able to mow late Thursday. Saturday was my second pass at it.
6,896
I bought my first tractor, a 2021 BX23S with 150 hours on it, a couple months ago. Went through and changed out the engine and hydraulic oils and filters, coolant, and front axle fluid. I was using the backhoe for the first time and noticed there were a few broken bolts on the ground underneath it. I then learned that the bottom pin, dipper pin, and thumb pin were all frozen and had sheared the cross bolts right off.
That's great that you got it fixed.
Make sure that you do not tighten the thru bolts holding the pins in place. They should be ny-lock nuts and the bolt should be able to spin freely. If you tighten them I can guarantee that you'll lose them and have pin walk out. ;)
6,896
cut/hauled a downed tree off the road for the neighbor yesterday.
Decided to catch up on some garage/tool organization.
Didn't get a chance to do anything with the Kubota today since the new pup found a nice cool place to relax.
Reactions: 14 users
MotoBBQ
L3902HST w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
51
304
53
MN
Didn't like the look of the grass on this jump. Decided to give it a 'tune-up'. My friends call this the 'send it' jump. Sits at the top of a hill where we land on the backside.
Then I dug a small drainage ditch for water run-off. A low lying part of the track, decided it was dry enough now. I'll add the dirt to the track to raise it up a little.
65hrs on the L3902 and still have not had its first regen. No issues, just feel like it's around the corner...
Reactions: 11 users
Gaspasser
L6060, FEL, forks, front snowblower. KX033 mini ex. Dump truck, Husqvarna saws.
Dec 16, 2023
441
696
NH
Finally the monsoon is over and a day of sun and temps in the 60's. Moved equipment/implements around on the few non-muddy areas. Removed chains. Mounted the box blade to provide ballast to counter fork loads. Have rake and grapple coming from Homestead Implements tomorrow and have to unload from delivery truck. Put up a second apiary fence and checked on the bees... all queens intact and laying. Amazing how motivating one sunny day can be. Weather guessers say tomorrow is going to be even better. Hoo-rah!
Reactions: 6 users
11,755
After some trial and tribulation I got the Scorpion control grip installed on the first SCD valve lever this afternoon. I didn't like my first attempt on Friday afternoon/evening but am liking what I ended up with. Of course I managed to break a 10-32 tap and couldn't get the broken part out so had to start half of the project over.
I modified the factory lever by cutting it down and welding the section of rod that mates to the modified bolt. I also modified the aluminum adapter that I ordered. The control grip has a 7/8 - 14 NF female thread at the base and the adapter I bought converted that to a 1/2" cylinder. I ended up cutting off the part that slips over a 1/2" rod and tapped the section inside the grip for 9/16-18. I then cut up a 9/16-18 bolt to mate with a 9/16" steel rod. The rest is self explanatory.
I need to find a decent connector (Deustch?) so that I can connect the control grip to the Summit Hydraulics multiplier/diverter rather than hard wire the cables. The reason for this is that that control grip needs to be removed along with the wire in order to install/remove the plastic cover plate.
I called Summit on Friday to ask for a wiring schematic so that I know how to connect the control grip to their multiplier since I'm not using the switch box. There are 8 wires on the multiplier but only 7 wires in the cable running to the first Deustch connector. That number drops to 6 wires that head up to the switch box. Checking continuity left me very confused.
Here's the "final" product. I painted the bare steel with Kubota grey before installing the control grip.
Reactions: 12 users
TheEnd
BX23S
Apr 17, 2025
Funny you mention that. I was going to tighten them snug, but I noticed all the other cross bolts were left loose. I assumed it was in case the nut became stuck it would be easier to cut the bolt if there was a gap. I left about 1/4" of gap and figured that was plenty for a cut off wheel. Didn't know there was another reason. Thanks for the heads up!
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
189
257
Hardy, VA
Unless you are some high-end precision user, the step drills at Harbor Freight are affordable and work well. They are well worth the investment to have floating around your bit collection ready for that time you can really use it.
BBFarmer
Jul 12, 2024
789
1,621
Terry, MS
Boy do I hate this driveway with every fiber of my being! We're not too far away from a complete reroute though. Slowly getting there. Gave her a couple passes to level everything out before the next storm
Which was only a hour or so away right as I started hauling more dirt up to driveway #2.
Parked her in a terrible spot and went inside to start cooking for the day. Now shes trapped at the top of the driveway where its super soft.
Bee-Positive
Nov 16, 2022
924
901
Amsterdam, NY
Had two days of no rain finally, thought I'd try mowing. Took one pass in 4WD and gave up. We have springs that come off a large hill and soak this side of the property. It's going to take at least a week of good weather to dry out. Maybe I'll wait and cut it for silage.
Reactions: 9 users
