No oil pressure after rebuild
Bgblock427
M7040, L4240 and ZD1211
Jun 21, 2024
25
9
Tennessee
I need a diagram of the oil circuit for a 3307 engine I don't see one in the manual.
If you have seen my previous posts I rebuilt a 3307 engine for a friend that we had problems getting parts for.
The engine fires up perfectly but no oil is getting to the oil pressure sensor. I verified that using a mechanical gauge that there is no oil.
My guess is one of the small expansion plugs under the front cover didn't need to be there. I checked the pump when it was apart and yes the o ring from the pick up tube was installed. I will be pulling the oil pump cover off today (not looking forward to it as the tractor is all back together.)
Hoping someone has a diagram on here, always a help! Thanks
or a photo of what plugs needed to be installed under the cover.
Bgblock427
Jun 21, 2024
25
9
Tennessee
pretty sure this is where i screwed up, i think i put a plug in this passage thinking it was a water passage
Hugo Habicht
G1900
Jun 24, 2024
1,164
1,694
Ireland
Parts list says "cap, sealing" for parts 150 though.
That would be a plug, wouldn't it?
10,007
Yes if you put a cap/plug where the red is there that is 100% your problem
That is an oil galley
The plug should be in the green spot only.
If you pull plug 100 (Yellow) you will see the cap/ plug in the block
Bgblock427
Jun 21, 2024
25
9
Tennessee
Yep. pulled the cover and the plug was in the hole, I feel better because I didn't install that plug the machine shop did. I can tell and the hit around the edges with a chisel to keep it from coming out. Checked oil and no glitter, engine was only ran a couple of min, so fingers crossed it didn't hurt the bearings. Ill post a pic later.
Bgblock427
Jun 21, 2024
25
9
Tennessee
Well here was the problem, once I seen it was staked in place I knew it was done by the machine shop. I do automotive engines so I didn't catch this on assembly. But when customer said no oil pressure I remembered the galley plugs in the front thinking they were for antifreeze and not a oil passage. At least it only took about 1,5 hours to get to the problem, now to reassemble and call it good.
Flintknapper
L2350DT
May 3, 2022
2,017
2,560
Deep East Texas
It may not be a bad idea to take a look at a few rod bearings.
Yep. Hopefully a generous amount of assembly lube was used on the crank journals. Otherwise, it wouldn't take long to ruin the rod bearings.
Or Crank Bearings for that matter.
Bgblock427
Jun 21, 2024
25
9
Tennessee
I use a clevite assembly lube that sticks like glue on the crank and rod bearings
